NetShelter WX enclosures are specifically designed for networking professionals to securely store and wire 19" EIA compatible equipment such as hubs, routers, concentrators and patch panels. Typical applications include small hub and LAN applications within wiring closets and computer rooms with floor space constraints. The NetShelter wall-mount enclosure mounts directly to building walls without occupying valuable or unavailable floor space. Rubber feet are provided with the enclosure for those applications that require floor mounting.
The company offers its NetShelter WX wall-mount enclosure 13U with a vented door.
Ships fully assembled
NetShelter VX Enclosures ship fully assembled reducing the time required to install equipment -
Doors open 180 degrees
Two people are often required to stand in front of an enclosure on opposite sides to install heavy rack-mount equipment. A door that opens 180 degrees allows for installation of equipment without the need to remove the door making installation fast and easy -
Adjustable Front Vertical Mounting Rail
The front mounting rails can be adjusted to allow for various mounting depths and to allow for additional clearance from the front door -
Adjustable mounting depth
Vertical mounting rails are adjustable for equipment with various mounting depths
- APC NetShelter WX - rack - 13U
- Product Type
- Rack
- Placing / Mounting
- Wall mountable
- Black
- Rack Size
- 19"
- Height (Rack Units)
- 13U
- Product Material
- Rubber, steel
- 58.4 cm x 61.6 cm x 65.4 cm
- 42.6 kg
- Lockable front door, vented
- Localisation
- Belgium, Albania, Argentina, Aruba, Colombia, Czech Republic, Estonia, Lithuania, Venezuela, Belize, Canada, Chile, Iceland, Mexico, Virgin Islands, Puerto Rico, Luxembourg, Hungary, Cyprus, Bolivia, Uruguay, Peru, Paraguay, Ecuador, Honduras, Guatemala, Costa Rica, Salvador, Panama, Nicaragua, Dominican Republic, Jamaica, Falkland Isles, Liechtenstein, Malta, Yugoslavia, Macedonia, Slovakia, Slovenia, Latvia, Guyana, Barbados, Antigua and Barbuda, Cayman Islands, Cuba, Anguilla, Andorra, Netherlands Antilles, Austria, Brazil, Denmark, Finland, France, Germany, Italy, Netherlands, Norway, Poland, Portugal, Spain, Sweden, Switzerland, United Kingdom, United States, Greece, Ireland
- 2-year warranty
- Designed For
- P/N: SUA1000RM2U, SUA1000RM2U-TU, SUA1000RMI2U
- Product Type
- Rack
- Wall mountable
- Product Material
- Rubber, steel
- Rack Size
- 19"
- 13U
- 58.4 cm
- 61.6 cm
- 65.4 cm
- 42.6 kg
- Black
- Localisation
- Weight Limit
- 45.4 kg
- Mounting Kit
- Included
- EIA-310-D
- Limited warranty: parts and labour - 2 years - carry-in
- Designed For
APC 750VA Line interactive rack mt | In Stock | £643.90 |
APC Basic Rack-Mount PDU - power distribution strip | In Stock | £200.74 |
APC 1U Horizontal Cable Organiser | In Stock | £54.38 |
APC Smart-UPS SC 450VA 1U | In Stock | £277.34 |
APC Rack PDU Basic 1U 16A 208&230V (10)C13 & (2)C19 | In Stock | £281.45 |
APC Smart-UPS X 1500VA Rack/Tower LCD 230V | In Stock | £1,186.60 |
APC Cable Managers (Qty 10) | In Stock | £35.29 |
APC 2U Horizontal Cable Organizer | In Stock | £57.58 |
APC Blanking Panel Kit | In Stock | £107.35 |
APC 1U Blanking Panel Kit | In Stock | £33.57 |
APC SMX1500RMI2UNC Smart-UPS 1500VA Rack/Tower LCD 230V with Net | In Stock | £1,644.28 |
APC Smart-UPS SRT 2200VA RM 230V | In Stock | £1,754.75 |
APC Metered Rack PDU | In Stock | £825.58 |
APC Smart-UPS 1500VA RM 230V w/Network Card | In Stock | £1,174.75 |
APC Switched Rack PDU AC 208-230 V Ethernet | In Stock | £727.91 |
APC Switched Rack PDU AP7922B Power Distribution Unit | In Stock | £1,070.54 |
APC Switched Rack PDU AP7920B Power Distribution Strip AC 200/20 | In Stock | £644.38 |
APC Smart-UPS C 1000VA 2U LCD - UPS (rack-mountable) | In Stock | £598.33 |
APC Smart-UPS 1000VA LCD RM - UPS (rack-mountable) | In Stock | £703.85 |
APC Smart-UPS 1500VA LCD RM - UPS (rack-mountable) | In Stock | £891.73 |
APC Rack PDU Basic 0U/1U 100-240V/ | In Stock | £80.80 |
APC Smart-UPS 750VA RM 230V SmartConnect | In Stock | £518.47 |
