APC Smart-UPS C 1000VA 2U LCD - UPS (rack-mountable)
Quicklinx: DJKHWS00 Mfr#: SMC1000I-2UC
Type: UPS
Power Rating: 600watt
14 In Stock
£604.80 ex VAT
£725.76 inc VAT
Marketing description is not available.
  • SmartConnect
    Innovative, easy to use remote monitoring feature that provides automatic notifications, firmware updates, and advanced support services.
  • Software package
    SmartConnect software for remote power monitoring feature availability varies by terms of use
  • Communication port support
    SmartConnect Ethernet port for cloud monitoring feature availability varies by terms of use
  • High online efficiency
    Reduces utility costs, generates less heat.
  • Green mode
    Patent-pending operating mode that bypasses unused electrical components in good power conditions to achieve very high operating efficiency without sacrificing any protection.
  • Pure sine wave output on battery
    Simulates utility power to provide the highest degree of compatibility for active PFC (power factor corrected) servers and sensitive electronics.
  • LCD Status Display
    Provides key UPS status at a glance. Multiple status indicators with load and battery bar graphs.
  • Cold-start capable
    Provides temporary battery power when the utility power is out.
  • Temperature-compensated battery charging
    Prolongs battery life by regulating the charge voltage according to battery temperature.
APC Smart-UPS C - UPS - 600 watt - 1000 VA - with APC SmartConnect
UPS - rack-mountable
Rack Size
2U
20.52 kg
Input Voltage
AC 230 V
Output Voltage
AC 230 V ± 5%
Power Capacity
600 watt / 1000 VA
Input Connectors
1 x power IEC 60320 C14
Lead Acid
Batteries Qty
1
USB, serial
43.2 cm x 40.6 cm x 8.9 cm
Bundled with
APC SmartConnect
P/N: AR2487G, AR3100W, AR3105SP, AR3105W, AR3140G, AR3140W, AR3150W, AR3155SP, AR3155W, AR3300W, AR3305W, AR3340G, AR3355SP, AR3355W, AR4018IX429, AR4018SP, AR4018SPX429, AR4018SPX431, AR4018SPX432, AR4018X429, AR4024IX431, AR4024SP, AR4024SPX429, AR4024SPX431, AR4024SPX432, AR4038IX432, NBWL0356A
Height (Rack Units)
2U
Bundled with
APC SmartConnect
UPS Technology
Line interactive
Input Voltage
AC 230 V
Input Voltage Range
AC 180 - 287 V
Input Voltage Range (Adjustable)
AC 170 - 300 V
Frequency Provided
57 - 63 Hz
Frequency Required
50/60 Hz
Input Connectors
Output Voltage
AC 230 V ± 5% - 57 - 63 Hz
Power Capacity
600 watt / 1000 VA
Output Waveform
Sinewave
Surge Suppression
Surge Energy Rating
459 joules
Circuit Protection
Circuit breaker
Quantity
1
Lead Acid
Run Time (Up To)
16 min at half load , 6 min at full load
Recharge Time
3 hours
Remote Management Interface
USB, serial
Power cable , USB cable - external
Rack Mounting Kit
Included
Audible alarm, LCD display, Automatic Voltage Regulation (AVR), cold-start function, automatic shut down reset, automatic self-test, hot-swappable batteries
C-Tick, GOST, UL 1449, VDE, RoHS, REACH
Software Included
APC PowerChute Business Edition
Limited warranty - parts and labour - 2 years
0 - 95%
Sound Emission
42 dBA
43.2 cm
40.6 cm
8.9 cm
20.52 kg
Shipping Width
59.4 cm
Shipping Depth
58.4 cm
Shipping Height
24.1 cm
Shipping Weight
22.33 kg
P/N: ACCS1000, ACCS1001, ACCS1002, ACCS1003, ACCS1004, ACCS1005, ACCS1006, ACCS1007, ACDC1015, ACDC1016, ACDC1017, ACDC1019, ACDC1020, ACDC1021, ACDC2513, ACF001, ACF002, ACF003, ACF101BLK, ACF102BLK, ACF201BLK, ACF400, ACF600, AP5017, AP5602, AP5606, AP5607, AP5616, AP92200, AP9290, AR100, AR100HD, AR202, AR203A, AR204A, AR2101, AR2102BLK, AR2144BLK, AR2145BLK, AR2200, AR2280, AR2400, AR2400FP1, AR2401, AR2407, AR2480, AR2487, AR2487G, AR2500, AR2507, AR2580, AR2587, AR2900, AR2901, AR3000, AR3100, AR3100G, AR3100SP, AR3100SP1, AR3100SP2, AR3100TAA, AR3100W, AR3100X609, AR3100X610, AR3100X617, AR3101, AR3104, AR3104SP1, AR3105, AR3105SP, AR3105W, AR3107, AR3107G, AR3107SP, AR3107X609, AR3107X610, AR3107X617, AR3130, AR3140, AR3140G, AR3140W, AR3150, AR3150SP, AR3150SP1, AR3150SP2, AR3150W, AR3150X609, AR3150X610, AR3150X617, AR3155, AR3155SP, AR3155W, AR3157, AR3157SP, AR3157X609, AR3157X610, AR3157X617, AR3200, AR3300, AR3300G, AR3300SP, AR3300W, AR3300X609, AR3300X610, AR3300X617, AR3305, AR3305SP, AR3305W, AR3307, AR3307SP, AR3307W, AR3307X609, AR3307X610, AR3307X617, AR3340, AR3340G, AR3340W, AR3347, AR3350, AR3350SP, AR3350W, AR3350X609, AR3350X610, AR3350X617, AR3355, AR3355SP, AR3355W, AR3357, AR3357SP, AR3357X609, AR3357X610, AR3357X617, AR4018, AR4018A, AR4018I, AR4018IA, AR4018IX429, AR4018IX431, AR4018IX432, AR4018SP, AR4018SPX429, AR4018SPX431, AR4018SPX432, AR4018X429, AR4018X431, AR4018X432, AR4024, AR4024A, AR4024I, AR4024IA, AR4024IX429, AR4024IX431, AR4024IX432, AR4024SP, AR4024SPX429, AR4024SPX431, AR4024SPX432, AR4024X429, AR4024X431, AR4024X432, AR4038, AR4038A, AR4038I, AR4038IA, AR4038IX429, AR4038IX431, AR4038IX432, AR4038X429, AR4038X432, AR7007, AR7050, AR7057, NBWL0356A
DJKH APC Power Cord IEC 320 C13 to IEC 320 C14 In Stock £30.50
DJKH APC Power Cord IEC 320 C19 TO IEC 320 C14 In Stock £51.81
DJKH APC Basic Rack-Mount PDU - power distribution strip In Stock £208.27
DJKH APC 1U Vertical Cable Organiser In Stock £125.73
DJKH APC 1U Horizontal Cable Organiser In Stock £55.58
DJKH APC Netshelter heavy duty shelf In Stock £143.31
DJKH APC Rack PDU, Basic, Zero U, 10A,2 In Stock £278.99
DJKH APC Rack PDU Basic Zero U 16A 208/230V In Stock £304.72
DJKH APC 2-Post Mounting Kit for Smart-UPS In Stock £175.52
DJKH APC Rack PDU Basic Zero U 32A 230V In Stock £328.79
DJKH APC Cable Managers (Qty 10) In Stock £36.45
DJKH APC 2G Power distribution strip In Stock £655.20
DJKH APC Rack PDU 2G METERED ZEROU In Stock £702.35
DJKH APC 1U 19" Black Modular Toolless Blanking Panel - Qty 200 In Stock £515.62
DJKH APC Rack PDU 2G, Metered, ZeroU, 11kW, 230V, (36) C13 & (6) C19 In Stock £1,002.83
DJKH APC 19" Rack LCD Console In Stock £1,385.79
DJKH APC Vertical Cable Organizer, NetShelter SX, 42U In Stock £96.64
DJKH APC Fixed Shelf - 50lbs/23kg, Black In Stock £81.58
DJKH APC Switched Rack PDU 2G Zero U Power Distribution Unit In Stock £1,518.27
DJKH APC NetShelter Zero U Accessory Mounting Bracket In Stock £99.93
DJKH APC Power Cord Kit (6 ea) Locking C13 to C14 0.6m In Stock £59.49
DJKH APC M6 Hardware Kit Rack Screws, Nuts and Washers In Stock £56.33
DJKH APC 1U 19" Black Modular Toolless Blanking Panel - Qty 10 In Stock £48.24
DJKH APC Power Cable (pack of 6) 1.22m In Stock £90.21
DJKH APC Rack PDU 2G Metered ZeroU 22.0kW In Stock £1,752.69
DJKH APC Horizontal Cable Manager, 1U x 4" Deep, Single-Sided In Stock £69.86
DJKH APC Power Cord Kit (6 ea) - Locking - C13 to C14 - 1.8m In Stock £133.04
DJKH APC Power Cord Kit (6 ea) Locking C13 to C14 (90 Degree) 1.2m In Stock £104.13
DJKH APC Rack PDU 2G Metered ZeroU 20A/208V 16A/230V In Stock £639.92
DJKH APC Metered Rack PDU In Stock £862.70
DJKH APC Switched Rack PDU AC 208-230 V Ethernet In Stock £767.49
DJKH APC Vertical Cable Manager for NetShelter SX 750mm Wide 42U In Stock £268.16
DJKH APC Switched Rack PDU AP7922B Power Distribution Unit In Stock £1,117.10
DJKH APC 1 Year Extended Warranty 2015-4037 In Stock £62.36
DJKH APC Service Pack 3 Year Warranty Extension In Stock £116.56
DJKH APC Basic Rack PDU AP6015A Power Distribution Unit In Stock £62.89
DJKH APC Switched Rack PDU AP7920B Power Distribution Strip AC 200/20 In Stock £683.34
DJKH APC Rack PDU 2G, Metered by Outlet with Switching, ZeroU In Stock £1,273.22
DJKH APC Basic PDU 1/2 Height 100-240V/20A 14xC13 In Stock £164.31
DJKH APC Rack PDU 2G, Metered by Outlet with Switching, ZeroU, 16A, 2 In Stock £1,309.42
DJKH APC Rack PDU Basic 0U/1U 100-240V/ In Stock £83.56
DJKH APC Metered Rack 12A 1U C13x8 Power Distribution Unit In Stock £473.12
Type: UPS
Brand: APC
Price Range Ex VAT: £500 - £750
