APC NetShelter WX 13U w/Threaded Hole Vertical Mounting Rail
Quicklinx: D9PGWS00 Mfr#: AR100HD
£557.77 ex VAT
£669.32 inc VAT
NetShelter WX enclosures are specifically designed for networking professionals to securely store and wire 19" EIA compatible equipment such as hubs, routers, concentrators and patch panels. Typical applications include small hub and LAN applications within wiring closets and computer rooms with floor space constraints. The NetShelter wall-mount enclosure mounts directly to building walls without occupying valuable or unavailable floor space. Rubber feet are provided with the enclosure for those applications that require floor mounting.
The company offers its NetShelter WX wall-mount enclosure 13U with a vented door.
  • Adjustable Front Vertical Mounting Rail
    The front mounting rails can be adjusted to allow for various mounting depths and to allow for additional clearance from the front door.
  • Ships fully assembled
    NetShelter VX Enclosures ship fully assembled reducing the time required to install equipment.
  • Doors open 180 degrees
    Two people are often required to stand in front of an enclosure on opposite sides to install heavy rack-mount equipment. A door that opens 180 degrees allows for installation of equipment without the need to remove the door making installation fast and easy.
  • Adjustable mounting depth
    Vertical mounting rails are adjustable for equipment with various mounting depths.
APC NetShelter WX - rack - 13U
Rack
Placing / Mounting
Wall mountable
Rack Size
19"
Height (Rack Units)
13U
Product Material
Rubber, steel
58.4 cm x 61.6 cm x 65.4 cm
42.6 kg
Lockable front door, vented
Belgium, Albania, Argentina, Aruba, Colombia, Czech Republic, Estonia, Lithuania, Venezuela, Belize, Canada, Chile, Iceland, Mexico, Virgin Islands, Puerto Rico, Luxembourg, Hungary, Cyprus, Bolivia, Uruguay, Peru, Paraguay, Ecuador, Honduras, Guatemala, Costa Rica, Salvador, Panama, Nicaragua, Dominican Republic, Jamaica, Falkland Isles, Liechtenstein, Malta, Yugoslavia, Macedonia, Slovakia, Slovenia, Latvia, Guyana, Barbados, Antigua and Barbuda, Cayman Islands, Cuba, Anguilla, Andorra, Netherlands Antilles, Austria, Brazil, Denmark, Finland, France, Germany, Italy, Netherlands, Norway, Poland, Portugal, Spain, Sweden, Switzerland, United Kingdom, United States, Greece, Ireland
P/N: SUA1000RM2U, SUA1000RM2U-TU, SUA1000RMI2U
Rack
Placing / Mounting
Wall mountable
Product Material
Rubber, steel
Rack Size
19"
Height (Rack Units)
13U
58.4 cm
61.6 cm
65.4 cm
42.6 kg
Weight Limit
45.4 kg
Mounting Kit
Included
EIA-310-D
Limited warranty: parts and labour - 2 years - carry-in
D9PG APC Basic Rack-Mount PDU - power distribution strip In Stock £205.26
D9PG APC 1U Horizontal Cable Organiser In Stock £55.67
D9PG APC Smart-UPS SC 450VA 1U In Stock £282.51
D9PG APC Rack PDU Basic 1U 16A 208&230V (10)C13 & (2)C19 In Stock £295.10
D9PG APC Smart-UPS X 1500VA Rack/Tower LCD 230V In Stock £1,192.48
D9PG APC Cable Managers (Qty 10) In Stock £36.51
D9PG APC 1U 19" Black Modular Toolless Blanking Panel - Qty 200 In Stock £514.24
D9PG APC Fixed Shelf - 50lbs/23kg, Black In Stock £81.26
D9PG APC 1U Blanking Panel Kit In Stock £34.92
D9PG APC 1U 19" Black Modular Toolless Blanking Panel - Qty 10 In Stock £48.98
D9PG APC Horizontal Cable Manager, 1U x 4" Deep, Single-Sided In Stock £69.35
D9PG APC SMX1500RMI2UNC Smart-UPS 1500VA Rack/Tower LCD 230V with Net In Stock £1,644.88
D9PG APC Smart-UPS SRT 2200VA RM 230V In Stock £1,810.37
D9PG APC Metered Rack PDU In Stock £850.25
D9PG APC Smart-UPS 1500VA RM 230V w/Network Card In Stock £1,188.85
D9PG APC Switched Rack PDU AP7922B Power Distribution Unit In Stock £1,101.80
D9PG APC Basic Rack PDU AP6015A Power Distribution Unit In Stock £62.39
D9PG APC Switched Rack PDU AP7920B Power Distribution Strip AC 200/20 In Stock £681.13
D9PG APC Smart-UPS C 1000VA 2U LCD - UPS (rack-mountable) In Stock £598.82
D9PG APC Smart-UPS 1000VA LCD RM - UPS (rack-mountable) In Stock £719.72
D9PG APC Smart-UPS 1500VA LCD RM - UPS (rack-mountable) In Stock £891.35
D9PG APC Rack PDU Basic 0U/1U 100-240V/ In Stock £84.53
D9PG APC Metered Rack 12A 1U C13x8 Power Distribution Unit In Stock £472.34
D9PG APC Smart-UPS 750VA RM 230V SmartConnect In Stock £527.45
Brand: APC
Price Range Ex VAT: £500 - £750
