The NetBotz 300 offers the best value for security and environmental monitoring over the network. An integrated camera allows video surveillance and monitoring to record human activity. It provides temperature, humidity, door contact, dry contact, spot leak, vibration, and smoke monitoring. Additional features like integration with InfraStruXure Central, Power over Ethernet, and user-defined alerts make the NetBotz 300 the perfect unit to protect your IT assets from security and environmental threats. The NetBotz 300 can be used in network closets to data centers, but it is commonly installed in network closets and server rooms.
NetBotz Room Monitor 355 features integrated camera and sensors (temperature, humidity, airflow, dewpoint, camera motion). It supports up to 4 universal sensors.
- NetBotz Room Monitor 355 - network surveillance camera - with 120/240V PoE Injector
- Network surveillance camera - fixed
- Bundled with
- 120/240V PoE Injector
- 17 cm x 9.5 cm x 21 cm
- 650 g
- Connectivity Technology
- Wired
- Ethernet 10Base-T/100Base-TX
- Voltage
- PoE
- 2 years warranty
- Environmental Parameters (operating)
- 0 °C - 45 °C
- Wired
- 17 cm
- 9.5 cm
- 21 cm
- 650 g
- Bundled with
Camera
- - fixed
- Network Interface
- Network Protocols
- DHCP, DNS, HTTP, SMTP, TCP/IP, SOCKS
- Alarm Inputs Qty
- 4
- 1 x network - Ethernet 10Base-T/100Base-TX - RJ-45
- Included Accessories
- Wall mount kit
- ICES-003, VCCI Class A ITE, FCC Part 15 A, C-Tick Class A
- Power Requirements
- PoE
- Limited warranty - 2 years
- 0 °C
- 45 °C
