Extends the Mobile Power Pack's battery life by automatically shutting down when the connected devices have completely charged.
Push-button activated LED display provides battery charge status.
Mobile power packs recharge all devices that connect to power using a USB cable, including your mobile phone, tablet, audio player, handheld gaming console, and e-reader.
- APC Mobile Power Pack power bank - Li-Ion - USB
- Product Type
- Power bank
- 3.2 cm x 7.2 cm x 2.2 cm
- 140 g
- Blue
- Output Connector Type
- USB
- Voltage Required
- 5 V
- Voltage Provided
- 5 V
- Max Electric Current
- 1 A
- Battery
- Lithium Ion - 3000 mAh
- Power Device Details
- - 4 pin USB Type A - 5 V - 1 A
- 1-year warranty
- Product Type
- Power bank
- Designed For
- Portable player, tablet, mobile phone
- 3.2 cm
- 7.2 cm
- 2.2 cm
- 140 g
- Enclosure Colour
- Blue
- Voltage Required
- 5 V
- Input Connectors
- 5 pin Micro-USB Type B
- Input Connectors Qty
- 1
- Voltage Provided
- 5 V
- Output connectors
- 4 pin USB Type A
- 1 A
- Overload protection, LED indicator, short circuit protection, overcharging protection, overheat protection, over-current protection, overdischarging protection
- Technology
- Lithium Ion
- Capacity
- 3000 mAh
- Recharge Time
- 4 hour(s)
- CB, FCC Part 15 B, RoHS, IEC 60950-1, EN 60950-1, REACH, IEC 62133, UN38.3
- Limited warranty - 1 year
C2G 5m USB 2.0 A/B Cable - Black | In Stock | £5.09 |
