Damaging power surges associated with lightning or utility problems can travel along your utility and data lines, damaging your electronic devices and destroying your valuable data. Even smaller everyday power surges can degrade the performance of your electronics and decrease their life. The APC SurgeArrest Essential series represents the minimum level of surge protection that should be present on any of your computers and household electronics, with most models also providing surge protection for your phone lines. Its state of the art circuitry offers protection for sensitive electronic equipment against larger power surges and multiple surge events.
180 degree Rotating Cord Retainer
A 180-degree rotating cord with strain relief offers flexibility in positioning the SurgeArrest, and in routing the power cord. -
3 Modes of protection (L-N : L-G : N-G)
The remaining modes continue to provide protection in the event a mode of protection is compromised as a result of a surge. -
Building Wiring Fault Indicator
This LED informs users of potentially dangerous wiring problems in the wall circuit. -
EMI and RFI noise filtering
Reduces line noise that can cause data loss and keyboard errors. -
Fail Safe Mode
Most other surge suppressors continue to let power through even after their circuits have been damaged, leaving your equipment exposed to future surges. APC's SurgeArrest fail safe, which means that once the circuit of an APC SurgeArrest has been compromised the unit disconnects equipment from the power supply ensuring that no damaging surges reach your equipment. -
Lightning and Surge Protection
To prevent damage to your equipment from electric power surges and spikes. -
Power Line Communications (PLC) compatible
Protects PLC network adapters without interrupting network communications. -
Protection Working Indicator
SurgeArrest will warn you if its circuitry has been damaged by heavy strike or power line surge and it is unable to provide 100% protection. If still under warranty, APC will then replace your damaged SurgeArrest free of charge. -
Safety-agency approved
Ensures the product has been tested and approved to work safely with the connected service provider equipment and within the specified environment.
- APC SurgeArrest Essential - surge protector
- Surge protector - external
- 0.7 kg
- Localisation
- United Kingdom
- Input Voltage
- AC 230 V
- Output Voltage
- AC 230 V
- Input Connectors
- 1 x power BS 1363
- Black
- 7 cm x 4.5 cm x 38.5 cm
- Limited lifetime warranty
- Black
- Localisation
- United Kingdom
- Input Voltage
- AC 230 V
- Frequency Provided
- 50/60 Hz
- Frequency Required
- 50/60 Hz
- Input Connectors
- 1 x power BS 1363
- Output Voltage
- AC 230 V 50/60 Hz
- Max Electric Current
- 13 A
- Surge Suppression
- Surge Response Time
- 1 ns
- Surge Energy Rating
- 903 Joules
- EMI/RFI Noise Filtration
- 30 dB
- Circuit Protection
- Circuit breaker
- Cables Included
- Power cable 1.8 m
- RoHS, REACH
- Limited warranty - lifetime
- 0 °C
- 40 °C
- 0 - 95%
- 7 cm
- 4.5 cm
- 38.5 cm
- 0.7 kg
- Shipping Width
- 13.5 cm
- Shipping Depth
- 5.2 cm
- Shipping Height
- 41.1 cm
