APC Back-UPS ES 550VA 120V 8 Output Connectors
Quicklinx: 7V2MWS00 Mfr#: BE550G
The Back-UPS provides abundant battery backup power, so you can work through medium length power outages. It safeguards your equipment against damaging surges and spikes that travel along utility and data lines. The Back-UPS also features automatic voltage regulation (AVR), which instantly adjusts high and low voltages to safe levels, so you can work indefinitely during brownouts and overvoltages.
The Back-UPS also includes unique "green" features, like power-saving outlets that automatically turn off idle peripherals. A high efficiency charging system and "AVR Bypass" also reduce power consumption. With the rest of the Back-UPS standard features, this is the perfect unit to protect your productivity from the constant threat of bad power and lost data.
  • Efficiency
    UPS products considered must achieve operational efficiency in the top 25 percent of the market, thus allowing customers to realize lower electrical operating costs and a smaller carbon footprint.
  • Performance tested
    All UPS products are subject to the EPA's Energy Star test procedure.
  • Easy-to-use auto shutdown software with power and energy management features
    PowerChute Personal Edition software provides safe system shutdown in the event of an extended power outage and prevents potential data corruption. Designed for exceptional usability, it provides first-time users with optimal protection based on APC industry-leading power management expertise. Users also have the option to tailor PowerChute settings for their individual circumstances. Energy cost and CO2 information provides a greater understanding of the energy consumed by protected equipment and energy plans enable cost savings.
APC Back-UPS ES 550 - UPS - 330 Watt - 550 VA
UPS - external
5.9 kg
Input Voltage
AC 120 V
Output Voltage
AC 120 V
Power Capacity
330 Watt / 550 VA
Input Connectors
1 x power NEMA 5-15
Output connectors
4 x power NEMA 5-15 (surge) , 4 x power NEMA 5-15 (UPS and surge)
Lead Acid
Battery Form Factor
Internal
Batteries Qty
1
Run Time (Up To)
3.2 min at full load
USB
30.5 cm x 17.8 cm x 8.4 cm
3-year warranty
P/N: ACF600, AR106, AR106SH4, AR106SH6, AR109SH4, AR109SH6, AR112, AR112SH4, AR112SH6, AR8213, NBWL0356A, SCL500RM1UC, SCL500RM1UNC, SMTL1000RM2UC, SMTL750RM2UC
UPS - external
Battery Enclosure Type
Internal
UPS Technology
Off-line
Input Voltage
AC 120 V
Input Voltage Range
AC 88 - 139 V
Frequency Provided
60 Hz
Frequency Required
60 Hz
Input Connectors
1 x power NEMA 5-15
Output Voltage
AC 120 V 60 Hz
Power Capacity
330 Watt / 550 VA
Dataline Surge Protection
Phone line - RJ-11
Output Waveform
Stepped approximation to a sinewave
Surge Suppression
Surge Energy Rating
365 Joules
Circuit Protection
Circuit breaker
Quantity
1
Lead Acid
Run Time (Up To)
Recharge Time
24 hours
Remote Management Interface
USB
1 x management (USB)
Power cable 1.8 m , USB cable
Equipment Protection Value
75000 US Dollars
Audible alarm, LED indicators
cUL, NOM, UL 1778, UL 497A, UL 497B, FCC Part 15 B, FCC Part 68, RoHS
Limited warranty - 3 years
5 - 95%
Sound Emission
45 dBA
30.5 cm
17.8 cm
8.4 cm
5.9 kg
Shipping Width
43.8 cm
Shipping Depth
14 cm
Shipping Height
24.1 cm
Shipping Weight
6.5 kg
