AOC Value i2080Sw 19.5" 1440x900 5ms VGA LED Monitor
Quicklinx: D6W4WS00 Mfr#: i2080Sw
The 19.5-inch AOC I2080SW handles all your home computing needs with excellent performance and sharp, clear imagery. Featuring an IPS panel, you'll enjoy accurate colors, wide viewing angles and impressive picture quality, whether you're editing photos or just surfing the web. Fast response time eliminates blurring to deliver smooth action sequences for more exciting movies and games. This versatile home display makes the perfect addition to your home office or living room, and the integrated VESA mount also gives you the possibility to hang it on the wall. With the built-in VGA connector, you can hook up your computer and get started fast.
  • IPS Panel
    No matter if you are viewing photos, videos, a magazine layout in InDesign or playing your favourite game – we want your content to look excellent from whatever angle you are seeing it. That is why this display comes with an advanced IPS panel, which produces brilliant colours and offers wide viewing angles. This way, images always look excellent and accurate, regardless from which angle you – or your friends and co-workers sitting or standing next to you – are looking at the screen.
  • Kensington Lock
    Kensington Lock is an anti-theft system, comprising a metal-reinforced hole in the body of the respective device, to use with a metal cable secured with a key/lock system. Kensington locks enable you to secure your AOC monitor during a LAN event, an organisation, or wherever you carry it.
  • Vesa Mount
    AOC's Ergo Base stands bring versatility, sturdiness and ease of use in one package. But do you still want to use your wall mount or multi-monitor setup using desk mounts? VESA mounts bring you the uppermost flexibility. Upside-down, in pivot mode, on top of each other, attach your monitor wherever you want using 3 rd party mounts and stands thanks to the VESA mount option.
AOC Value i2080Sw - LED monitor - 19.5"
LED-backlit LCD monitor - 19.5"
Panel Type
IPS
Aspect Ratio
16:10
Native Resolution
1440 x 900 at 60 Hz
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 20000000:1 (dynamic)
Response Time
5 ms
Colour Support
16.7 million colours
Input Connectors
VGA
Voltage
45.46 cm x 19 cm x 37.5 cm
2.14 kg
Environmental Standards
ENERGY STAR Qualified
Plug and Play, TUV, FCC, RoHS, REACH, EuP, EAC
3-year warranty
Display Type
Diagonal Size
19.5"
Panel Type
IPS
Aspect Ratio
16:10
Native Resolution
1440 x 900 at 60 Hz
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms
Vertical Refresh Rate
50 - 76 Hz
Horizontal Refresh Rate
30 - 83 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
I-Menu
45.46 cm x 19 cm x 37.5 cm - with stand
2.14 kg
VGA
Mechanical
Tilt Angle
-5/+23
VESA Mounting Interface
100 x 100 mm
1 x VGA cable
Input Voltage
Power Consumption (Typical)
19 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption (Off Mode)
0.3 Watt
Sustainability Information
ENERGY STAR Certified
Limited warranty - 3 years
