Modernized design and crisp Full HD images. The 22B2H/EU combines a sleek 3-sides frameless panel and VGA and HDMI connectivity. Enjoy working or streaming with wide viewing angles and eye-soothing LowBlue and FlickerFree technologies.
Frameless design
Besides looking modern and attractive, frameless designs enable seamless multi-monitor setups. Your cursor/windows will not be lost anymore in the dark abyss of bezels, when many displays are placed side by side. -
FHD Resolution
Want to watch a Blu-ray movie in full quality, enjoy games in high resolution or read crisp text in office applications? Thanks to its Full HD resolution of 1920 x 1080 pixels, this monitor lets you do just that. Whatever you are viewing, with Full HD it will be displayed in rich detail without requiring a high-end graphics card or consuming a lot of your system's resources. -
VA Panel
VA Panels (Vertical Alignment) display deeper blacks and a high contrast for extra vivid and bright images. -
Low Blue Light
AOC Lowblue Light protects you from harmful blue light which, during long sessions, has been shown to cause eye strain, headaches, and sleeping disorders. Our Lowblue Light feature reduces the harmful wavelengths emitted without sacrificing colour composition, setting the experience free from the worry of eye damage. -
Flicker Free
AOC Flicker-Free Technology utilises a DC (Direct Current) backlight panel, reducing flickering light levels. With eye strain and fatigue absolutely minimised, feel free to enjoy those long, intense gaming sessions in comfort!
- AOC 22B2H/EU - LED monitor - Full HD (1080p) - 22"
- LED-backlit LCD monitor - 22"
- Energy Label QR Code URL
- Https://eprel.ec.europa.eu/qr/413333
- Energy Class
- Class E
- Energy Consumption per Year
- 30 kWh
- Power Consumption (On mode)
- 18 W
- Panel Type
- VA
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080 at 75 Hz
- Pixel Pitch
- 0.2482 mm
- Brightness
- 200 cd/m²
- Contrast Ratio
- 3000:1 / 20000000:1 (dynamic)
- Response Time
- 4 ms
- Colour Support
- 16.7 million colours
- Colour Gamut
- 77% Adobe RGB, 98% sRGB
- Input Connectors
- HDMI, VGA
- Tilt
- Screen Coating
- 3H Hard Coating
- Voltage
- AC 120/240 V (50/60 Hz)
- Black
- 49.278 cm x 16.294 cm x 38.811 cm
- 2.1 kg
- Environmental Standards
- ENERGY STAR Qualified
- FCC, EAC
- 3-year warranty
- Display Type
- Energy Class
- Class E
- Energy Class (HDR)
- Class F
- 30 kWh
- Diagonal Size
- 22"
- Viewable Size
- 21.5"
- Panel Type
- VA
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.2482 mm
- Brightness
- 200 cd/m²
- Contrast Ratio
- Colour Support
- Colour Gamut
- Response Time
- 4 ms
- Vertical Refresh Rate
- 50 - 76 Hz
- Horizontal Refresh Rate
- 30 - 83 kHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- 3H Hard Coating
- Backlight Technology
- WLED
- OSD Languages
- Multilingual
- Low Blue Light Mode, Flicker Free technology, Wide Viewing Angle, 3-sided frameless
- Black
- 49.278 cm x 16.294 cm x 38.811 cm - with stand
- 2.1 kg
- VGA , HDMI , Headphones
Mechanical
- Tilt
- Tilt Angle
- -5/+21,5
- VESA Mounting Interface
- 100 x 100 mm
- Cables Included
- HDMI cable - 1.8 m
- FCC, EAC
- Security Slot Type
- Kensington security slot
- Input Voltage
- 18 W
- Power Consumption SDR (On mode)
- 16 kWh/1000h
- Power Consumption HDR (On mode)
- 18 kWh/1000h
- Power Consumption (Typical)
- 20 watt
- Power Consumption Stand by
- 0.3 watt
- 0.3 watt
- Dimensions & Weight Details
- With stand - width: 49.278 cm - depth: 16.294 cm - height: 38.811 cm - weight: 2.1 kg , Without stand - width: 49.278 cm - depth: 3.62 cm - height: 29.268 cm
- Shipping Width
- 55 cm
- Shipping Depth
- 12 cm
- Shipping Height
- 37 cm
- Shipping Weight
- 3.5 kg
Sustainability Information
- ENERGY STAR Certified
- Limited warranty - 3 years
