This large widescreen monitor boasts a non-glare LED-backlit TN panel with Full HD resolution. Delivering a response time of only 5 ms and a static contrast of 1000:1, the 70 series member comes well-equipped for both multimedia and office applications. Connecting analog signals via D-Sub and digitally via its DVI port. This energy-efficient display fulfils strict sustainability certificates such as Energy Star 6.0, TCO 6.0 and EPEAT Gold.
Vivid visuals
Experience true-to-life colors with the AOC E2370SD's 23-inch display, boasting a dynamic contrast ratio of 20,000,000:1 and 16.7 million color support. The Full HD 1080p resolution ensures crisp, clear images for an immersive viewing experience. -
Ergonomic design
Designed with your comfort in mind, the AOC E2370SD features tilt adjustments allowing you to find the perfect viewing angle, reducing strain during long usage periods. -
Seamless connectivity
Equipped with both DVI-D and VGA interfaces, this monitor offers versatile connectivity options, making it easy to connect to a wide range of devices.
- AOC E2370SD - LED monitor - Full HD (1080p) - 23"
- LED-backlit LCD monitor - 23"
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080 at 60 Hz
- Pixel Pitch
- 0.265 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1 / 20000000:1 (dynamic)
- Colour Support
- 16.7 million colours
- Input Connectors
- DVI-D, VGA
- Tilt
- Voltage
- AC 120/230 V (50/60 Hz)
- Environmental Standards
- ENERGY STAR Qualified
- TUV GS, GOST, FCC, RoHS, ISO 9241-307, EuP, NRTL
- 3-year warranty
- Display Type
- Diagonal Size
- 23"
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.265 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- Colour Support
- Vertical Refresh Rate
- 50 - 75 Hz
- Horizontal Refresh Rate
- 30 - 83 kHz
- Video Bandwidth
- 148.5 MHz
- Horizontal Viewing Angle
- 170
- Vertical Viewing Angle
- 160
- Backlight Technology
- WLED
- HDCP, Eco-Mode, i-Menu, e-Saver technology, Screen+
- DVI-D , VGA
Mechanical
- Tilt
- Tilt Angle
- -5/+15
- VESA Mounting Interface
- 100 x 100 mm
- Cables Included
- 1 x VGA cable , 1 x DVI cable
- Security Slot Type
- Kensington security slot
- Power Supply
- Internal
- Input Voltage
- Power Consumption (Typical)
- 18 Watt
- Power Consumption Stand by
- 0.5 Watt
- Power Consumption Sleep
- 0.3 Watt
- Included Software
- Drivers & Utilities
Sustainability Information
- ENERGY STAR Certified
- Limited warranty - 3 years
