AOC Q2778VQE 27" 2560×1440 1ms DVI-D HDMI DP LED Monitor
Quicklinx: B8NRWS00 Mfr#: Q2778VQE
Experience a new level of sharpness with this large 68.5 cm (27") monitor. The Q2778VQE utilizes a state-of-the-art TN panel with the stunning WQHD resolution of 2560 x 1440 pixels. With its D-Sub, DVI-D, HDMI and DisplayPort connectors, this energy-efficient display offers you a multitude of applications, delivering exceptionally crisp and vivid images for even the highest demands. Benefit further from flexibility tilt and swivel function. The Q2778VQE comes in a glossy black design and features eco-friendly LED-backlights. Let the Q2778VQE impress you today!
  • QHD Resolution
    With 2560 x 1440 resolution, Quad HD (QHD) offers superior picture quality and sharp imagery that reveals the finest details. The widescreen 16:9 aspect ratio provides plenty of space to spread out and work, plus allows you to enjoy games or movies in their original size.
  • Vesa Mount
    AOC's Ergo Base stands bring versatility, sturdiness and ease of use in one package. But do you still want to use your wall mount or multi-monitor setup using desk mounts? VESA mounts bring you the uppermost flexibility. Upside-down, in pivot mode, on top of each other, attach your monitor wherever you want using 3 rd party mounts and stands thanks to the VESA mount option.
  • Display Port
    The most recent display interface standard from VESA, DisplayPort can also transfer audio, USB and other forms of data. DisplayPort version 1.2-1.2a support up to 165 Hz@1440p, 75 Hz@2160p, version 1.3 supports up to 240Hz@1440p, 120 Hz@2160p and the version 1.4 supports HDR10 specifications.
AOC Q2778VQE - LED monitor - 27"
LED-backlit LCD monitor - 27"
Energy Class
Class C
Energy Consumption per Year
67 kWh
Power Consumption (On mode)
46 W
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
QHD 2560 x 1440 at 60 Hz
Pixel Pitch
0.2331 mm
Brightness
350 cd/m²
Contrast Ratio
1000:1 / 80000000:1 (dynamic)
Response Time
1 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
HDMI, DVI, DisplayPort, VGA
Display Position Adjustments
Tilt
Voltage
Black, silver
64.03 cm x 29.91 cm x 47.07 cm
4.72 kg
Environmental Standards
ENERGY STAR Qualified
RoHS, Lead-Free, REACH, TUV Bauart, EAC, ISO 9241-307 Class 1, Mercury-free
3-year warranty
Display Type
Energy Class
Class C
67 kWh
Diagonal Size
27"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2331 mm
Brightness
350 cd/m²
Contrast Ratio
Colour Support
Response Time
1 ms (grey-to-grey)
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Backlight Technology
WLED
Controls & Adjustments
Volume, brightness, contrast, H/V position, sharpness, gamma correction, input select, graphic / text mode, phase, clock, luminance
OSD Languages
Czech, Chinese (traditional), Chinese (simplified), English, German, French, Italian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Japanese, Korean
HDCP
Black, silver
64.03 cm x 29.91 cm x 47.07 cm - with stand
4.72 kg
DVI , HDMI , VGA (HD-15) , DisplayPort
Mechanical
Tilt
Tilt Angle
-4/+21
VESA Mounting Interface
100 x 100 mm
1 x VGA cable - 1.2 m , 1 x DVI cable - 1.5 m , 1 x DisplayPort cable - 1.5 m
MTBF
50,000 hour(s)
Input Voltage
46 W
Power Consumption (Typical)
45 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption (Off Mode)
0.5 Watt
On / Off Switch
No
Shipping Width
72.9 cm
Shipping Depth
21.5 cm
Shipping Height
55.5 cm
Shipping Weight
6.77 kg
Sustainability Information
ENERGY STAR Certified
ENERGY STAR Version
6.0
Limited warranty - 3 years
