Enjoy brilliantly colored, vivid images on this large 60.4 cm (23.8?) widescreen monitor. Boasting a high-grade IPS panel with Full HD resolution, the I2475PXJ delivers exceptionally wide viewing angles for multimedia and office applications. With its D-Sub, DVI-D and HDMI connectors, plus speakers, this energy-efficient display offers you a multitude of options. Benefit from full ergonomic flexibility with 130mm height adjustment, tilt, swivel and pivot (= portrait mode rotation) functions. The I2475PXJ comes in a classy texturized design and features eco-friendly LED backlights. Let this stylish monitor impress you today!
Full HD resolution
Want to watch a Blu-ray movie in full quality, enjoy games in high resolution or read crisp text in office applications? Thanks to its Full HD resolution of 1920 x 1080 pixels, this monitor lets you do just that. Whatever you are viewing, with Full HD it will be displayed in rich detail without requiring a high-end graphics card or consuming a lot of your system's resources. -
Height-adjustable stand
AOC cares about your well-being. This is why this monitor offers height adjustment options, which help you find your perfect posture while working, playing or watching videos. Adapting your AOC monitor to your needs not only helps you reduce fatigue and keep your body healthy. In the end it lets you and your team achieve better results in whatever you are doing. -
Speakers
Built-in speakers make it easy to catch up with family, friends and colleagues. For movies, music, games and more, you'll enjoy quality audio without the hassle of connecting external speakers.
 - AOC Pro-line I2475PXJ - LED monitor - Full HD (1080p) - 23.8"
 - LED-backlit LCD monitor - 23.8"
- Energy Class
 - Class A
- Energy Consumption per Year
 - 33 kWh
- Power Consumption (On mode)
 - 23 W
- Panel Type
 - IPS
- Aspect Ratio
 - 16:9
- Native Resolution
 - Full HD (1080p) 1920 x 1080 at 60 Hz
- Pixel Pitch
 - 0.2745 mm
- Brightness
 - 250 cd/m²
- Contrast Ratio
 - 1000:1 / 50000000:1 (dynamic)
- Response Time
 - 5 ms
- Colour Support
 - 16.7 million colours
- Input Connectors
 - DVI-D, VGA, HDMI (MHL)
 - Height, pivot (rotation), swivel, tilt
- Voltage
 - AC 120/230 V (50/60 Hz)
 - Black
 - 55.14 cm x 22.1 cm x 40.04 cm
 - 6 kg
- Environmental Standards
 - ENERGY STAR Qualified
 - Plug and Play, TUV GS, FCC, RoHS, DICOM Part 14, REACH, TUV Bauart, EuP, EAC, BFR-free
 - 3-year warranty
- Display Type
- Energy Class
 - Class A
 - 33 kWh
- Diagonal Size
 - 23.8"
- Panel Type
 - IPS
- Aspect Ratio
 - 16:9
- Native Resolution
- Pixel Pitch
 - 0.2745 mm
- Brightness
 - 250 cd/m²
- Contrast Ratio
- Colour Support
- Response Time
 - 5 ms
- Vertical Refresh Rate
 - 50 - 76 Hz
- Horizontal Refresh Rate
 - 30 - 83 kHz
- Horizontal Viewing Angle
 - 178
- Vertical Viewing Angle
 - 178
- Backlight Technology
 - LED backlight
 - HDCP, i-Menu, e-Saver technology, Zero power switch
 - Black
 - 55.14 cm x 22.1 cm x 40.04 cm - with stand
 - 6 kg
Audio
 - Speakers
 - VGA , MHL / HDMI , DVI , Headphones
Mechanical
- Tilt Angle
 - -5/+25
- Swivel Angle
 - 165
- Height Adjustment
 - 130 mm
- VESA Mounting Interface
 - 100 x 100 mm
- Cables Included
 - 1 x VGA cable , 1 x DVI cable , 1 x audio cable , 1 x USB cable
- Input Voltage
 - 23 W
- Power Consumption (Typical)
 - 30 Watt
- Power Consumption Stand by
 - 0.5 Watt
 - 0.5 Watt
- On / Off Switch
Sustainability Information
- ENERGY STAR Certified
 - Limited warranty - 3 years
