AOC M2060PWDA2  19.5 INCH LED Monitor  1920 x 1080
Quicklinx: BZRFWS00 Mfr#: M2060PWDA2
This model targets business and home office users alike. Hidden behind its classically designed case is the panel technology. It boasts a high typical contrast, Full HD resolution, a fast response time and wide viewing angles for amazing imaging performance.
  • Integrated Speakers
    Built-in speakers make it easy to catch up with family, friends and colleagues. For movies, music, games and more, you'll enjoy quality audio without the hassle of connecting external speakers.
  • Height adjustable stand
    We care about your well-being. This is why this monitor offers height adjustment options, which help you find your perfect posture while working, playing or watching videos. Adapting your AOC monitor to your needs not only helps you reduce fatigue and keep your body healthy. In the end it lets you and your team achieve better results in whatever you are doing.
  • Full HD Resolution
    Want to watch a Blu-ray movie in full quality, enjoy games in high resolution or read crisp text in office applications? Thanks to its Full HD resolution of 1920 x 1080 pixels, this monitor lets you do just that. Whatever you are viewing, with Full HD it will be displayed in rich detail without requiring a high-end graphics card or consuming a lot of your system's resources.
  • Kensington Lock
    Kensington Lock is an anti-theft system, comprising a metal-reinforced hole in the body of the respective device, to use with a metal cable secured with a key/lock system. Kensington locks enable you to secure your AOC monitor during a LAN event, an organisation, or wherever you carry it.
AOC Pro-line M2060PWDA2 - LED monitor - Full HD (1080p) - 19.53"
LED-backlit LCD monitor - 19.53"
Energy Label QR Code URL
Https://eprel.ec.europa.eu/qr/413384
Energy Class
Class E
Power Consumption (On mode)
13.4 W
Stereo speakers
Aspect Ratio
16:9
Native Resolution
Brightness
250 cd/m²
Contrast Ratio
3000:1 / 20000000:1 (dynamic)
Response Time
7 ms
Colour Support
16.7 million colours
Input Connectors
DVI, VGA
Display Position Adjustments
Voltage
47.76 cm x 35.83 cm x 17.95 cm
Environmental Standards
ENERGY STAR Qualified
Plug and Play, TUV, RoHS
3-year warranty
Display Type
Energy Class
Class E
Diagonal Size
19.53"
Built-in Devices
Stereo speakers
Aspect Ratio
16:9
Native Resolution
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
7 ms
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
WLED
HDCP, i-Care
47.76 cm x 35.83 cm x 17.95 cm - with stand
Audio
Speakers - stereo
Output Power / Channel
2 Watt
VGA , DVI
Mechanical
Tilt Angle
-5/+22
1 x VGA cable , 1 x DVI cable , 1 x audio cable
Input Voltage
13.4 W
13.4 kWh/1000h
Power Consumption (Typical)
23 Watt
Power Consumption Stand by
0.3 Watt
Power Consumption Sleep
0.3 Watt
Power Consumption (Off Mode)
0.3 Watt
Sustainability Information
ENERGY STAR Certified
Limited warranty - 3 years
BZRF C2G 2m HDMI to DVI-D Digital Video Cable In Stock £6.86
