AOC I2490PXQU/BT 23.8" 1920x1080 4ms HDMI VGA DisplayPort LED Monitor
Quicklinx: D6WJWS00 Mfr#: i2490PXQU/BT
The AOC I2490PXQU has an appealing look with 3-sided frameless design and a flexible, sturdy stand with multiple ergonomic options. Its 23.8-inch IPS panel delivers sharp and vivid images covering 90% of the NTSC and 100% of the sRGB color gamut. The I2490PXQU excels at color uniformity and color accuracy. In addition to its wide viewing angles of up to 178°, its ergonomic base supports -5° /25° tilt, -165°/165° swivel, 130 mm height adjustment and pivot (90°) capability, which guarantees working comfort in every setting. Its HDMI, VGA and DisplayPort inputs offer a variety of connection options. Users spending long hours in front of a monitor will be relieved with the Flicker-Free technology reducing flicker by regulating backlight, and the low blue light mode reducing the harmful short wavelength blue light. The energy-efficient I2490PXQU is also certified with ecolabels such as Energy Star, EPEAT and TCO.
  • Frameless design
    Besides looking modern and attractive, frameless designs enable seamless multi-monitor setups. Your cursor/windows will not be lost anymore in the dark abyss of bezels, when many displays are placed side by side.
  • Wide Colour Gamut
    When you are enjoying photos, videos or games, we want your screen content to look as lifelike as possible. That is why this display comes with Wide Colour Gamut technology, which means that it is able to display a lot more colours than conventional monitors. This is achieved through a special hardware solution, not through mere software adjustments. The result: true-to-life images with fine details that become visible thanks to the broader colour palette.
  • Flicker Free
    AOC Flicker-Free Technology utilises a DC (Direct Current) backlight panel, reducing flickering light levels. With eye strain and fatigue absolutely minimised, feel free to enjoy those long, intense gaming sessions in comfort!
  • Height adjustable Stand
    Raise or lower the screen to suit each individual's height and seating preferences. The easy-to-adjust stand ensures hours of comfort.
  • Speakers
    Built-in speakers make it easy to catch up with family, friends and colleagues. For movies, music, games and more, you'll enjoy quality audio without the hassle of connecting external speakers.
  • Three-Year Warranty
    AOC stands behind the quality of each and every monitor with a generous three-year warranty starting from the original date of purchase. Within the warranty period, any AOC displays with manufacturing defects or faulty components will be repaired or replaced at no additional charge.
AOC I2490PXQU/BT - LED monitor - Full HD (1080p) - 23.8"
LED-backlit LCD monitor - 23.8"
Energy Label QR Code URL
Https://eprel.ec.europa.eu/qr/396472
Energy Class
Class E
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2745 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 20000000:1 (dynamic)
Response Time
4 ms
Input Connectors
HDMI, VGA, DisplayPort
Display Position Adjustments
Height, swivel, tilt
Voltage
AC 100 - 240 V (50/60 Hz)
3-year warranty
Display Type
Energy Class
Class E
Diagonal Size
23.8"
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2745 mm
Brightness
250 cd/m²
Contrast Ratio
Response Time
4 ms
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
WLED
Audio
Speakers
Output Power / Channel
2 Watt
VGA , HDMI , DisplayPort , Audio line-in
Mechanical
Tilt Angle
-3.5/+19.5
Swivel Angle
20
Height Adjustment
130 mm
1 x VGA cable , 1 x HDMI cable , 1 x DisplayPort cable
Input Voltage
17 kWh/1000h
Limited warranty - 3 years
