AOC I2476VWM 23.6" 1920x1080 5ms VGA HDMI IPS LED Monitor
Quicklinx: B3LHWS00 Mfr#: I2476VWM
The AOC i2476Vwm display will impress the most demanding users. This 23.6-inch ADS-IPS screen has Full HD 1920 x 1080 resolution for brilliantly detailed movies and images with wide 178 degree viewing. Gamers will appreciated the fast 5ms response time that reduces ghosting and blur, and 50M:1 dynamic contrast offers rich, true blacks. The headphone jack and 2 watt speakers deliver crystal-clear sound for music or video calls with friends. Hook up your computer, laptop or game console with the built-in VGA and HDMI connectors. The stylish black finish and ultra-slim profile make it an elegant accent to your office or living room, while the VESA mount lets you hang it on the wall. The i2476Vwm display is the ideal choice for anyone who wants the ultimate image quality and performance at an attractive price.
  • Wide viewing angles
    With 178 degrees horizontal and vertical viewing angles, the AOC I2476VWM monitor offers a consistent viewing experience from almost any perspective, making it ideal for sharing content with friends or colleagues.
  • Vivid color display
    Experience the full spectrum with 16.7 million colors and a dynamic contrast ratio, delivering deeper blacks, brighter whites, and more vivid colors.
  • Energy efficient
    Certified by ENERGY STAR, this monitor is not only eco-friendly but also economical, with an energy consumption of just 32 kWh per year and a power consumption in on mode of only 22 W.
  • Seamless connectivity
    Equipped with HDMI and VGA interfaces, the monitor allows for easy and versatile connections to your computer and other devices.
  • Enhanced viewing comfort
    Featuring tilt adjustments from -4 to +21.5 degrees, the AOC I2476VWM monitor can be easily positioned for optimal viewing comfort, reducing strain during long usage sessions.
AOC Value I2476VWM - LED monitor - Full HD (1080p) - 23.6"
LED-backlit LCD monitor - 23.6"
Energy Class
Class A
Energy Consumption per Year
32 kWh
Power Consumption (On mode)
22 W
Panel Type
ADS-IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2715 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 50000000:1 (dynamic)
Response Time
5 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
HDMI, VGA
Display Position Adjustments
Tilt
Voltage
55.81 cm x 18.34 cm x 42.78 cm
3.84 kg
Environmental Standards
ENERGY STAR Qualified
Plug and Play, GOST, RoHS, ISO 9241-307, cTUVus, TUV Bauart, EuP
3-year warranty
Display Type
Energy Class
Class A
32 kWh
Diagonal Size
23.6"
Panel Type
ADS-IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2715 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms (grey-to-grey)
Vertical Refresh Rate
50 - 76 Hz
Horizontal Refresh Rate
30 - 83 kHz
Video Bandwidth
148.5 MHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
WLED
HDCP, Eco-Mode, i-Menu, e-Saver technology, Mobile High-Definition Link (MHL), Screen+
3.84 kg
VGA , HDMI
Mechanical
Tilt
Tilt Angle
-4/+21.5
VESA Mounting Interface
100 x 100 mm
1 x HDMI cable , 1 x audio cable , 1 x power cable , 1 x VGA cable
Power Supply
Internal
Input Voltage
22 W
Power Consumption (Typical)
26 Watt
Power Consumption Stand by
0.5 Watt
On / Off Switch
No
Sustainability Information
ENERGY STAR Certified
Limited warranty - 3 years
