IPS monitor i2352Vh provides wide viewing angle, ensuring consistent images from any viewing position. With this technology, monitor shows greater image depth with less color shift. The solid panel will not show any tails and puddles if the surface is touched.
The native 16:9 aspect ratio of i2352Vh means that typical HD media can be viewed full screen without distortion or annoying black bars. The i2352Vh have an analog input, DVI, HDMI as well as speakers. Ultra-high dynamic contrast of 20,000,000:1 reveals more depth and detail in darker scenes.
The slim Full HD model with a black finish comes with an IPS panel and LED backlights. VGA, DVI and HDMI inputs allow the connection of numerous multimedia sources. Its IPS-typical wide viewing angles (up to 178° horizontal/vertical), high brightness and contrast values (250 cd/m² and 1,000:1 / 20,000,000:1) as well ms response time provide an excellent image quality making the display perfect for action games and thrilling movies at home. For clearer, more vivid colours the Clear Vision function converts images from Standard Definition (SD) to High Definition (HD).
Product Details
- Inputs: D-SUB, DVI-D, HDMI
- 1920 x 1080 maximum resolution
- Special Features: -3°~19° Tilt,5:4 switch,Clear Vision Function,DCB,Eco Mode,e-Saver,i-Menu,Off Timer,screen+,VESA 75 mm
- 250 cd/m²
- 5 ms
- AOC i2352Vh - LED monitor - Full HD (1080p) - 23"
- LED-backlit LCD monitor - 23"
- Energy Class
- Class C
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080 at 80 Hz
- Pixel Pitch
- 0.2652 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 20000000:1 (dynamic)
- Response Time
- 5 ms
- Colour Support
- 16.7 million colours
- Input Connectors
- HDMI, DVI, VGA
- Speakers
- Integrated
- Tilt
- Voltage
- AC 120/230 V (50/60 Hz)
- Black
- 54.8 cm x 19 cm x 39.9 cm
- Microsoft Certification
- Compatible with Windows 7
- Environmental Standards
- ENERGY STAR Qualified
- TUV GS, VCCI, BSMI, GOST, DDC-2B, FCC, DDC/CI, RoHS, WEEE, halogen-free
- 3-year warranty
- Display Type
- Energy Class
- Class C
- Diagonal Size
- 23"
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.2652 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- Colour Support
- Response Time
- 5 ms
- Vertical Refresh Rate
- 76 Hz
- Horizontal Refresh Rate
- 83 kHz
- Video Bandwidth
- 148.5 MHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Backlight Technology
- LED backlight
- Controls & Adjustments
- Volume
- HDCP, e-Saver technology
- Black
- 54.8 cm x 19 cm x 39.9 cm - with stand
Audio
- Speakers - stereo - integrated
- VGA , DVI-D , HDMI , Audio line-in
Mechanical
- Tilt
- Tilt Angle
- -3/+19
- VESA Mounting Interface
- 75 x 75 mm
- Included Accessories
- Stand
- Power Supply
- Internal
- Input Voltage
- Power Consumption (Typical)
- 40 Watt
- Power Consumption Stand by / Sleep
- 0.5 Watt
- Dimensions & Weight Details
- With stand - width: 54.8 cm - depth: 19 cm - height: 39.9 cm , Without stand - weight: 3.2 kg
Sustainability Information
- ENERGY STAR Certified
- Limited warranty - 3 years - on-site
- 0 °C
- 40 °C
- 10 - 85% (non-condensing)
