AOC Gaming G2260VWQ6 21.5" 1920x1080 1ms VGA HDMI DisplayPort LED Monitor
Quicklinx: FB66WS00 Mfr#: G2260VWQ6
21.5-inch gaming monitor with FreeSync , 1ms and Anti-Blue Light.
  • Anti-blue light
    AOC Anti-Blue Light protects you from harmful blue light which, during long sessions, has been shown to cause eye strain, headaches, and sleeping disorders. Our Anti-Blue Light feature reduces the harmful wavelengths emitted without sacrificing colour composition, setting the experience free from the worry of eye damage.
  • 1ms Response Time
    A pixel response time of 1ms GTG means speed without the smear for an enhanced experience. Fast-moving action and dramatic transitions will be rendered smoothly without the effects of ghosting.
  • FreeSync
    Whatever your setup, achieve the highest framerate and smoothest display possible via AMD Free-Sync Technology. Whether you're dashing through explosions or screeching around rain slicked bends, wave goodbye to screen tearing and lag – and leave your opponents in your smoothly rendered dust.
  • DisplayPort Connection
    The most recent display interface standard from VESA, DisplayPort can also transfer audio, USB and other forms of data. DisplayPort version 1.2-1.2a support up to 165 Hz@1440p, 75 Hz@2160p, version 1.3 supports up to 240Hz@1440p, 120 Hz@2160p and the version 1.4 supports HDR10 specifications.
  • Display Port
AOC Gaming G2260VWQ6 - LCD monitor - Full HD (1080p) - 21.5"
LCD monitor - 21.5"
Energy Label QR Code URL
Https://eprel.ec.europa.eu/qr/399178
Energy Class
Class F
Energy Consumption per Year
35 kWh
Power Consumption (On mode)
18 W
Adaptive-Sync Technology
AMD FreeSync
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.248 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 20000000:1 (dynamic)
Response Time
1 ms
Colour Support
16.7 million colours
Input Connectors
HDMI, VGA, DisplayPort
Display Position Adjustments
Tilt
Voltage
51.18 cm x 18.44 cm x 37.69 cm
Environmental Standards
ENERGY STAR Qualified
Plug and Play, TUV GS, FCC, RoHS, TUV Bauart, EAC
Bundled Services
Re-Spawned 3 Year Advance Replacement and Zero Dead Pixel Guarantee / 1 Year One-Time Accident Damage Exchange
Display Type
LCD monitor / TFT active matrix
Energy Class
Class F
35 kWh
Diagonal Size
21.5"
AMD FreeSync
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.248 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
1 ms
Vertical Refresh Rate
48 - 76 Hz
Horizontal Refresh Rate
30 - 83 kHz
Video Bandwidth
148.5 MHz
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
OSD Languages
Czech, Chinese (traditional), Chinese (simplified), English, German, French, Italian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Japanese, Korean
HDCP, i-Menu, e-Saver technology, Screen+, Flicker Free technology, Anti-Blue Light technology
51.18 cm x 18.44 cm x 37.69 cm - with stand
VGA , HDMI , DisplayPort
Mechanical
Tilt
Tilt Angle
-5/+20
VESA Mounting Interface
100 x 100 mm
Wall mountable, VESA interface support
Stand
1 x VGA cable - 1.8 m , 1 x power cable - 1.8 m , 1 x HDMI cable - 1.8 m , 1 x DisplayPort cable - 1.8 m
Input Voltage
18 W
18 kWh/1000h
Power Consumption (Typical)
20 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption Sleep
0.3 Watt
On / Off Switch
No
Sustainability Information
ENERGY STAR Certified
Bundled Services
