The visually impressive U2879VF combines an expansive 28? screen size with 4K Ultra HD resolution for super-sharp, highly detailed images. The 10-bit Deep Color panel can display over a billion hues simultaneously, for superb realism and natural shading. A blisteringly fast screen response time shows fast-moving action without blurring, while AMD FreeSync technology matches the graphics signal to the screen timing to eliminate stuttering and tearing.
Ultra-high dynamic contrast intelligently adjusts brightness to reveal darker image details with greater depth and clarity. A full range of input connectors, including fast DisplayPort and dual-link DVI technologies, ensure compatibility with every device. The audio jack allows convenient attachment of headphones or desktop speakers.
1ms Response Time
A pixel response time of 1ms GTG means speed without the smear for an enhanced experience. Fast-moving action and dramatic transitions will be rendered smoothly without the effects of ghosting. -
4K UHD resolution
Ultra high definition 3840 x 2160 resolution (4K UHD) yields a superior pixel density of 157 PPI (pixels per inch) on the large 28-inch screen, for outstandingly detailed images. The 10-bit Deep Color RGB display panel ensures substantially more natural transitions between hues for exceptional realism. -
FreeSync
Gaming occasionally? AOC delivers smooth gameplay with AMD's FreeSync technology, which matches the framerate output of your GPU to your monitor's refresh rate, eliminating input lag, screen tear and stuttering. By choosing AOC, you won't stay behind innovations. -
Display Port
The most recent display interface standard from VESA, DisplayPort can also transfer audio, USB and other forms of data. DisplayPort version 1.2-1.2a support up to 165 Hz@1440p, 75 Hz@2160p, version 1.3 supports up to 240Hz@1440p, 120 Hz@2160p and the version 1.4 supports HDR10 specifications.
- AOC U2879VF - LED monitor - 28"
- LED-backlit LCD monitor - 28"
- Energy Label QR Code URL
- Https://eprel.ec.europa.eu/qr/337820
- Energy Class
- Class F
- Power Consumption (On mode)
- 27.3 W
- Adaptive-Sync Technology
- AMD FreeSync
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- 4K UHD (2160p) 3840 x 2160 (DisplayPort: 60 Hz, HDMI1: 30 Hz, HDMI2: 60 Hz, DVI: 30 Hz)
- Pixel Pitch
- 0.16 mm
- Brightness
- 300 cd/m²
- Contrast Ratio
- 1000:1 / 80000000:1 (dynamic)
- Response Time
- 1 ms (grey-to-grey)
- Colour Support
- 1.073 billion colours (8-bit)
- Input Connectors
- HDMI (MHL), VGA, DVI-D, DisplayPort
- Tilt
- Voltage
- AC 120/230 V (50/60 Hz)
- Black & silver
- 65.93 cm x 4.87 cm x 37.94 cm
- 4 kg
- Plug and Play, BSMI, DDC-2B, CCC, FCC, RoHS, WEEE, cTUVus, EPA, DDC-2B/CI, RCM, ISO9241-307
- 3-year warranty
- Display Type
- Energy Class
- Class F
- Diagonal Size
- 28"
- AMD FreeSync
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.16 mm
- Pixel Per Inch
- 157
- Brightness
- 300 cd/m²
- Contrast Ratio
- Colour Support
- Response Time
- Vertical Refresh Rate
- 23 - 80 Hz
- Horizontal Refresh Rate
- 30 - 140 kHz
- Horizontal Viewing Angle
- 170
- Vertical Viewing Angle
- 160
- Backlight Technology
- LED backlight
- OSD Languages
- Czech, Chinese (traditional), Chinese (simplified), English, German, French, Italian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Japanese, Korean
- Picture in picture, picture by picture, power off timer, HDCP, i-Menu, e-Saver technology, Screen+, Flicker Free technology
- Black & silver
- 4 kg
- VGA , MHL / HDMI , DVI-D (dual link) (HDCP) , DisplayPort , Headphones
Mechanical
- Tilt
- Tilt Angle
- -3.5/+23.5
- Security lock slot (cable lock sold separately), LED indicator
- Security Slot Type
- Kensington security slot
- Input Voltage
- 27.3 W
- Power Consumption SDR (On mode)
- 27.3 kWh/1000h
- Power Consumption (Typical)
- 49 Watt
- Power Consumption Stand by
- 0.32 Watt
- 0.23 Watt
- Shipping Width
- 73.2 cm
- Shipping Depth
- 15.9 cm
- Shipping Height
- 54.3 cm
- Shipping Weight
- 5.26 kg
- Limited warranty - parts and labour - 3 years
- 0 °C
- 40 °C
- 10 - 85% (non-condensing)
