The F22+ will appeal to everybody who attaches great importance to an attractive model combined with outstanding technical features. Thanks to its innovative small folding base the display can be easily placed on every desk and save space. The navigation ring integrated in the frame facilitates easy adjustment.
The display surface offers enough space for large-area presentations and multi-media demonstrations in 16:9 format. The viewing angle of 170°/160° and a high resolution provide for pin sharp images. Absolute color fidelity is achieved by the Dynamic Color Boost (DCB) method.
- AOC F22+ - LCD monitor - Full HD (1080p) - 21.5"
- LCD monitor - 21.5"
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080 at 60 Hz
- Pixel Pitch
- 0.248 mm
- Brightness
- 300 cd/m²
- Contrast Ratio
- 60000:1 (dynamic)
- Response Time
- 5 ms
- Colour Support
- 16.7 million colours
- Input Connectors
- DVI-D, VGA
- Voltage
- AC 120/230 V (50/60 Hz)
- Piano polish
- 52.6 cm x 8.1 cm x 37.9 cm
- 4.6 kg
- Microsoft Certification
- Certified for Windows Vista
- DDC-1, DDC-2B, ISO 13406-2, TUV S, CCC, FCC, DDC/CI, RoHS, cULus
- 3-year warranty
- Display Type
- LCD monitor / TFT active matrix
- Diagonal Size
- 21.5"
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.248 mm
- Brightness
- 300 cd/m²
- Contrast Ratio
- 60000:1 (dynamic)
- Colour Support
- Response Time
- 5 ms
- Vertical Refresh Rate
- 75 Hz
- Horizontal Refresh Rate
- 80 kHz
- Video Bandwidth
- 148 MHz
- Horizontal Viewing Angle
- 170
- Vertical Viewing Angle
- 160
- Eco-Mode, glossy, Dynamic Color Boost
- Piano polish
- 4.6 kg
- DVI-D , VGA
- Security lock slot (cable lock sold separately), wall mountable
- Certified for Windows Vista software and devices have undergone compatibility tests for ease-of-use, better performance and enhanced security.
- Security Slot Type
- Kensington security slot
- Input Voltage
- Power Consumption (Typical)
- 49 Watt
- Power Consumption Stand by / Sleep
- 1 Watt
- Limited warranty - 3 years
