The e970Swn offers great image quality at 1366 x 768 resolution. The 19-inch class monitor is EPEAT Silver and ENERGY STAR certified. Slim in design with extra narrow bezel and 20M: 1 contrast ratio.
Kensington Lock
Kensington Lock is an anti-theft system, comprising a metal-reinforced hole in the body of the respective device, to use with a metal cable secured with a key/lock system. Kensington locks enable you to secure your AOC monitor during a LAN event, an organisation, or wherever you carry it. -
Vesa Mount
AOC's Ergo Base stands bring versatility, sturdiness and ease of use in one package. But do you still want to use your wall mount or multi-monitor setup using desk mounts? VESA mounts bring you the uppermost flexibility. Upside-down, in pivot mode, on top of each other, attach your monitor wherever you want using 3rd party mounts and stands thanks to the VESA mount option.
- AOC E970SWN - LED monitor - 18.5"
- LED-backlit LCD monitor - 18.5"
- Aspect Ratio
- Widescreen
- Native Resolution
- 1366 x 768 at 60 Hz
- Pixel Pitch
- 0.3 mm
- Brightness
- 200 cd/m2
- Contrast Ratio
- 20000000:1 (dynamic)
- Response Time
- 5 ms
- Colour Support
- 16.7 million colours
- Input Connectors
- VGA
- Tilt
- Black
- 43.74 cm x 15.6 cm x 33.68 cm - with stand
- 2.15 kg
- Environmental Standards
- ENERGY STAR Qualified , EPEAT Silver
- C-Tick, BSMI, CCC, FCC, RoHS, ISO 9241-307, cTUVus, CECP, EPA, DDC-2B/CI
- 3 years warranty
- VESA
- Display Type
- Diagonal Size
- 18.5"
- Aspect Ratio
- Widescreen
- Native Resolution
- Pixel Pitch
- 0.3 mm
- Brightness
- 200 cd/m2
- Contrast Ratio
- Colour Support
- Response Time
- 5 ms
- Horizontal Viewing Angle
- 90
- Vertical Viewing Angle
- 65
- Backlight Technology
- LED backlight
- Black
- 2.15 kg
- VGA
Mechanical
- Tilt
- Tilt Angle
- -3/+10
- Flat Panel Mount Interface
- 100 x 100 mm
- Voltage Required
- AC 120/230 V ( 50/60 Hz )
- 15 Watt
- Power Consumption Stand by
- 0.5 Watt
- EPEAT Compliant
- EPEAT Silver
- 3 years warranty
- Service & Support Details
- Limited warranty - 3 years
StarTech.com Dual Monitor Mount - Articulating Arms - Grommet or Desk Mount | In Stock | £139.14 |
StarTech.com Articulating Monitor Arm | In Stock | £121.96 |
StarTech.com Dual Monitor Stand | In Stock | £82.12 |
StarTech.com TV/Monitor Arm - Wallmount | In Stock | £85.61 |
StarTech.com Monitor Arm - Heavy Duty | In Stock | £95.48 |
