AOC E950Swnk 18.5" 1366 x 768 VGA 5MS LED Monitor
Quicklinx: 8JJXWS00 Mfr#: E950SWNK
This model is characterized by the latest display technology with LED backlights, a top performance and a timelessly classic, black design. Due to high contrast and brightness values as well as a quick response time, the monitor renders even the fastest movie sequences fluently and razor-sharp. At its slimmest region, this elegant display, which sports hairline textures on the rear side as well as the base, is just 1.6 cm deep. Thanks to numerous features it is recommended for both office and home.
AOC Value e950Swnk - LED monitor - 18.5"
LED-backlit LCD monitor - 18.5"
Aspect Ratio
16:9
Native Resolution
1366 x 768 at 60 Hz
Pixel Pitch
0.3 mm
Brightness
200 cd/m²
Contrast Ratio
600:1 / 20000000:1 (dynamic)
Response Time
5 ms
Colour Support
16.7 million colours
Input Connectors
VGA
Display Position Adjustments
Tilt
Voltage
Glossy black
44.435 cm x 17.5 cm x 34.2 cm
Environmental Standards
ENERGY STAR Qualified
TUV GS, GOST, DDC-1, DDC-2B, CB, FCC, DDC/CI, RoHS, ISO 9241-307
3-year warranty
Display Type
Diagonal Size
18.5"
Aspect Ratio
16:9
Native Resolution
1366 x 768 at 60 Hz
Pixel Pitch
0.3 mm
Brightness
200 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms
Vertical Refresh Rate
76 Hz
Horizontal Refresh Rate
60 kHz
Video Bandwidth
85 MHz
Horizontal Viewing Angle
90
Vertical Viewing Angle
65
Backlight Technology
WLED
Controls & Adjustments
Contrast, aspect control
Power off timer, Eco-Mode, i-Menu, e-Saver technology, Screen+
Glossy black
VGA
Mechanical
Tilt
Tilt Angle
-4/+17
VESA Mounting Interface
75 x 75 mm
1 x VGA cable
Power Supply
Internal
Input Voltage
Power Consumption (Typical)
18 Watt
Power Consumption Stand by / Sleep
0.5 Watt
Included Software
Drivers & Utilities
Sustainability Information
ENERGY STAR Certified
Limited warranty - 3 years
