AOC E2461FWH 23.6" 1920 x 1080 2MS VGA HDMI LED Monitor
Quicklinx: 8J7NWS00 Mfr#: E2461FWH
The stylish e2461Fwh comes with an ultra-fast response time of just two milliseconds and will amaze you with its crystal-clear pictures. Even fast-paced action sequences from the latest games or movies are displayed sharply and without blurring. Brilliant colors, a strong typical contrast (1000:1) and high brightness impress you on a large scale. In addition, the Full HD 59.9 cm (23.6") screen is equipped with LED backlights, helping you reduce energy consumption - thus making it particularly economical despite its great performance. A simple yet elegant red edging of the foot accentuates the classy black design.
  • Fast 2ms response time
    These displays make sure you'll never miss out on the action. Quick 2ms response time virtually eliminates ghosting and blur, making it ideal for gaming, watching movies or editing videos.From high-speed car chases to fast-paced combat, you'll always enjoy an immersive, lag-free viewing experience.
  • Three-Year Warranty
    AOC stands behind the quality of each and every monitor with a generous three-year warranty starting from the original date of purchase. Within the warranty period, any AOC displays with manufacturing defects or faulty components will be repaired or replaced at no additional charge. Read the complete AOC warranty statement for more information.
  • HDMI input
    High Definition Multimedia Interface or HDMI is a global standard for digitally transmitting high-definition video and multichannel audio. This versatile single-cable solution allows you to easily connect your display to devices like computers, laptops, game consoles and media players.
AOC Style-line e2461Fwh - LED monitor - Full HD (1080p) - 23.6"
LED-backlit LCD monitor - 23.6"
Energy Class
Class B
Energy Consumption per Year
37 kWh
Power Consumption (On mode)
25 W
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2715 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 50000000:1 (dynamic)
Response Time
2 ms (gray-to-gray)
Colour Support
16.7 million colours
Input Connectors
HDMI, VGA
Display Position Adjustments
Tilt
Voltage
54.548 cm x 21.4 cm x 40.051 cm
2.6 kg
Environmental Standards
ENERGY STAR Qualified
GOST, FCC, RoHS, ISO 9241-307, cTUVus, TUV Bauart, EuP
3-year warranty
Display Type
Energy Class
Class B
37 kWh
Diagonal Size
23.6"
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2715 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
2 ms (gray-to-gray)
Vertical Refresh Rate
55 - 75 Hz
Horizontal Refresh Rate
30 - 83 kHz
Video Bandwidth
148.5 MHz
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Backlight Technology
LED backlight
HDCP, Eco-Mode, i-Menu, e-Saver technology, Screen+
2.6 kg
HDMI , VGA
Mechanical
Tilt
Tilt Angle
-3/+18
VESA Mounting Interface
75 x 75 mm
1 x VGA cable , 1 x HDMI cable
Input Voltage
25 W
Power Consumption (Typical)
17.3 Watt
Power Consumption Stand by / Sleep
0.3 Watt
0.3 Watt
Power Consumption Sleep
0.2 Watt
On / Off Switch
No
Included Software
Drivers & Utilities
Sustainability Information
ENERGY STAR Certified
Limited warranty - 3 years
