AOC E2460PHU 24" 1920 x 1080 2MS VGA DVI HDMI Height Adjustable LED Monitor
Quicklinx: 8B6GWS00 Mfr#: E2460PHU
This model targets business and home office users alike. Hidden behind its classically designed case is the latest LED technology. It boasts a high typical contrast, an ultra-fast response time and wide viewing angles for excellent imaging performance. With the i-Care function, the monitor adapts the panel's brightness to the ambient light. This means a more comfortable viewing experience, whilst lowering the energyconsumption at the same time. The environmentally friendly display comes in an elegant, textured finish.
AOC Value e2460Phu - LED monitor - Full HD (1080p) - 24"
LED-backlit LCD monitor - 24"
Energy Class
Class B
Energy Consumption per Year
37 kWh
Power Consumption (On mode)
25 W
Speaker
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.276 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 20000000:1 (dynamic)
Response Time
2 ms
Colour Support
16.7 million colours
Input Connectors
HDMI, DVI-D, VGA
Speakers
Integrated
Display Position Adjustments
Voltage
56.54 cm x 24.45 cm x 52.42 cm
6.54 kg
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified EPEAT Silver
TUV GS, DDC-1, DDC-2B, FCC, DDC/CI, RoHS, ISO 9241-307
3-year warranty
Display Type
Energy Class
Class B
37 kWh
Diagonal Size
24"
Built-in Devices
Speaker
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.276 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
2 ms
Vertical Refresh Rate
75 Hz
Horizontal Refresh Rate
80 kHz
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Backlight Technology
WLED
HDCP, Eco-Mode, i-Menu, e-Saver technology, Screen+, i-Care, Ionic Breeze
6.54 kg
Audio
Speakers - stereo - integrated
VGA , HDMI , DVI-D , USB
Mechanical
Tilt Angle
-5/+20
Swivel Angle
178
Rotation Angle
90
Height Adjustment
130 mm
VESA Mounting Interface
100 x 100 mm
1 x VGA cable , 1 x audio cable , 1 x USB cable , 1 x power cable , 1 x DVI cable
Power Supply
Internal
Input Voltage
25 W
Power Consumption Stand by
0.5 Watt
On / Off Switch
Microsoft Windows 7
Sustainability Information
EPEAT Compliant
EPEAT Silver
ENERGY STAR Certified
Limited warranty - 3 years
8B6G StarTech.com Dual Monitor Mount - Articulating Arms - Grommet or Desk Mount In Stock £139.14
8B6G StarTech.com Articulating Monitor Arm In Stock £124.94
8B6G StarTech.com Dual Monitor Stand In Stock £82.12
8B6G StarTech.com TV/Monitor Arm - Wallmount In Stock £84.28
