- AOC e2350Sda - LED monitor - Full HD (1080p) - 23"
- LED-backlit LCD monitor - 23"
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080 at 60 Hz
- Pixel Pitch
- 0.26 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1 / 20000000:1 (dynamic)
- Response Time
- 5 ms
- Colour Support
- 16.7 million colours
- Input Connectors
- DVI-D, VGA
- Speakers
- Integrated
- Tilt
- Voltage
- AC 120/230 V (50/60 Hz)
- 54.9 cm x 20.5 cm x 40.1 cm
- 3.5 kg
- Microsoft Certification
- Compatible with Windows 7
- Environmental Standards
- ENERGY STAR Qualified
- TUV GS, GOST, DDC-1, DDC-2B, CB, FCC, DDC/CI, RoHS, ISO 9024-307
- 3-year warranty
- Display Type
- Diagonal Size
- 23"
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.26 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- Colour Support
- Response Time
- 5 ms
- Vertical Refresh Rate
- 83 Hz
- Horizontal Refresh Rate
- 75 kHz
- Video Bandwidth
- 148.5 MHz
- Horizontal Viewing Angle
- 170
- Vertical Viewing Angle
- 160
- Backlight Technology
- WLED
- Power off timer, HDCP, Eco-Mode, i-Menu, e-Saver technology
- 3.5 kg
Audio
- Speakers - integrated
- VGA , DVI-D
Mechanical
- Tilt
- Tilt Angle
- -4/+17
- VESA Mounting Interface
- 75 x 75 mm
- Security lock slot (cable lock sold separately), wall mountable
- Cables Included
- 1 x VGA cable , 1 x audio cable
- Input Voltage
- Power Consumption (Typical)
- 31 Watt
- Power Consumption Stand by / Sleep
- 0.5 Watt
- Included Software
- Drivers & Utilities
- OS Required
- Microsoft Windows 7
Sustainability Information
- ENERGY STAR Certified
- Limited warranty - 3 years
