This LED-backlit monitor delivers a solid performance for standard office and home applications. Coming in a classy black texturised finish, the tiltable widescreen model is equipped with a fast-reacting TN panel, boasting a 5 ms pixel response time for crisp, blur-free images. Intelligent programs such as Screen+ and i-Menu enhance the user experience and help to save energy. The eco-friendly Series 70 fulfils demanding sustainability certificates such as Energy Star 6.0 and EPEAT Silver and is prepared for both VESA wall mount and Kensington security devices.
5ms Response Time
A pixel response time of 5ms GTG means speed without the smear for an enhanced experience. Fast-moving action and dramatic transitions will be rendered smoothly without the effects of ghosting. -
Kensington Lock
Kensington Lock is an anti-theft system, comprising a metal-reinforced hole in the body of the respective device, to use with a metal cable secured with a key/lock system. Kensington locks enable you to secure your AOC monitor during a LAN event, an organisation, or wherever you carry it. -
Vesa Mount
AOC's Ergo Base stands bring versatility, sturdiness and ease of use in one package. But do you still want to use your wall mount or multi-monitor setup using desk mounts? VESA mounts bring you the uppermost flexibility. Upside-down, in pivot mode, on top of each other, attach your monitor wherever you want using 3 rd party mounts and stands thanks to the VESA mount option. -
LED-backlight
AOC's monitors use LED backlights with white LEDs to illuminate the display panel (TN, IPS or VA). Compared to old backlights using CCFL, LED backlights have much lower energy consumption and more dimming control over the brightness, and contribute to the thinness of the display.
- AOC E2070SWN - LED monitor - 19.5"
- LED-backlit LCD monitor - 19.5"
- Energy Label QR Code URL
- Https://eprel.ec.europa.eu/qr/393942
- Energy Class
- Class E
- Power Consumption (On mode)
- 13.8 W
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- 1600 x 900 at 60 Hz
- Pixel Pitch
- 0.271 mm
- Brightness
- 200 cd/m²
- Contrast Ratio
- 20000000:1 (dynamic)
- Response Time
- 5 ms
- Colour Support
- 16.7 million colours
- Input Connectors
- VGA
- Tilt
- Voltage
- AC 120/230 V (50/60 Hz)
- Black
- 46.5 cm x 15.6 cm x 34.4 cm
- 2.27 kg
- Environmental Standards
- EPEAT Silver
- C-Tick, BSMI, DDC-2B, CCC, FCC, DDC/CI, RoHS, ISO 9241-307, cTUVus, CECP
- 3-year warranty
- Display Type
- Energy Class
- Class E
- Diagonal Size
- 19.5"
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.271 mm
- Brightness
- 200 cd/m²
- Contrast Ratio
- Colour Support
- Response Time
- 5 ms
- Vertical Refresh Rate
- 50 - 76 Hz
- Horizontal Refresh Rate
- 30 - 83 kHz
- Video Bandwidth
- 170 MHz
- Horizontal Viewing Angle
- 90
- Vertical Viewing Angle
- 65
- Backlight Technology
- WLED
- Black
- 2.27 kg
- VGA
Mechanical
- Tilt
- VESA Mounting Interface
- 100 x 100 mm
- Wall mountable
- Input Voltage
- 13.8 W
- Power Consumption SDR (On mode)
- 13.8 kWh/1000h
- Power Consumption (Typical)
- 18 Watt
- Power Consumption Stand by
- 0.5 Watt
Sustainability Information
- EPEAT Compliant
- EPEAT Silver
- Limited warranty - 3 years
