The C32G1 is equipped with a huge, frameless panel with a curvature and high resolution.
Flicker Free
AOC Flicker-Free Technology utilises a DC (Direct Current) backlight panel, reducing flickering light levels. With eye strain and fatigue absolutely minimised, feel free to enjoy those long, intense gaming sessions in comfort! -
FreeSync
Whatever your setup, achieve the highest framerate and smoothest display possible via AMD Free-Sync Technology. Whether you're dashing through explosions or screeching around rain slicked bends, wave goodbye to screen tearing and lag – and leave your opponents in your smoothly rendered dust. -
144Hz Refresh Rate
Equip yourself with twice the frame rate of other monitors and say goodbye to image stuttering and blurry motion. With a 144Hz refresh rate every frame is rendered sharply and in smooth succession, so you can line up your shots accurately and appreciate high speed races in all their glory. -
Minimal bezel distraction for the ultimate battle station
Expand your view with multiple monitor set-up. The narrow border and frameless design offer the minimal bezel distraction for the ultimate battle station. -
1800R curvature
Curved design wraps around you putting you at the centre of the action and provides an immersive gaming experience.
- AOC C32G1 - LED monitor - curved - Full HD (1080p) - 31.5"
- LED-backlit LCD monitor - 31.5"
- Energy Class
- Class A
- Energy Consumption per Year
- 54 kWh
- Power Consumption (On mode)
- 37 W
- Curved Screen
- Panel Type
- VA
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080 (DisplayPort: 144 Hz, HDMI: 144 Hz, VGA: 60 Hz)
- Pixel Pitch
- 0.3637 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 3000:1 / 80000000:1 (dynamic)
- Response Time
- 1 ms
- Colour Support
- 16.7 million colours
- Input Connectors
- 2xHDMI, VGA, DisplayPort
- Tilt
- Black
- 71.31 cm x 24.49 cm x 53.03 cm
- 6.98 kg
- Bundled Services
- Re-Spawned 3 Year Advance Replacement and Zero Dead Pixel Guarantee / 1 Year One-Time Accident Damage Exchange
- Display Type
- Energy Class
- Class A
- 54 kWh
- Diagonal Size
- 31.5"
- Viewable Size
- 31.5"
- Curved Screen
- Yes (1800R)
- Panel Type
- VA
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.3637 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- Colour Support
- Response Time
- 1 ms
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Backlight Technology
- WLED
- OSD Languages
- Czech, Chinese (traditional), Chinese (simplified), English, German, French, Italian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Japanese, Korean
- Low Blue Light Mode, Flicker Free technology
- Black
- 71.31 cm x 24.49 cm x 53.03 cm - with stand
- 6.98 kg
- 2 x HDMI , DisplayPort , VGA , Audio line-out
Mechanical
- Tilt
- Tilt Angle
- -5/+21,5
- Cables Included
- 1 x HDMI cable
- MTBF
- 50,000 hour(s)
- Voltage Required
- AC 100/240 V (50/60 Hz)
- 37 W
- 50 Watt
- Power Consumption Stand by
- 0.5 Watt
- 0.5 Watt
- Shipping Width
- 80.7 cm
- Shipping Depth
- 24.2 cm
- Shipping Height
- 55.1 cm
- Shipping Weight
- 9.1 kg
- Bundled Services
