AOC AOC Value M2470SWH - LED monitor - 23.6" (23.6" viewable) -
Quicklinx: D3NJWS00 Mfr#: M2470Swh
With Full HD resolution and high contrast ratios, the 23.6-inch M2470SWH display offers brilliant picture quality and sharp, clear imagery - even on the darkest areas of the screen. Perfect for a range of home computing requirements, this monitor really excels at fast-paced entertainment like games and movies with ultra-fast 1 ms response time for lag-free action. Advanced MVA panel technology delivers ultra-wide viewing angles of 178 degrees to ensure you'll see every detail, no matter where you're sitting. Integrated VGA and HMDI ports make it easy to connect your computer, media center, game console and more, plus the built-in speakers and headphone jack are ideal for listening to music or catching up with friends.
  • MVA Panel
    The MVA (Multi-Domain Vertical Alignment) panel displays deeper blacks and a -high contrast for extra vivid and bright images.
  • Integrated Speakers
    Built-in speakers make it easy to catch up with family, friends and colleagues. For movies, music, games and more, you'll enjoy quality audio without the hassle of connecting external speakers.
  • Full HD Resolution
    Want to watch a Blu-ray movie in full quality, enjoy games in high resolution or read crisp text in office applications? Thanks to its Full HD resolution of 1920 x 1080 pixels, this monitor lets you do just that. Whatever you are viewing, with Full HD it will be displayed in rich detail without requiring a high-end graphics card or consuming a lot of your system's resources.
AOC M2470SWH - LED monitor - Full HD (1080p) - 23.6"
LED-backlit LCD monitor - 23.6"
Energy Label QR Code URL
Https://eprel.ec.europa.eu/qr/405265
Energy Class
Class E
Panel Type
MVA
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2715 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 50000000:1 (dynamic)
Input Connectors
2xHDMI, VGA
Speakers
Integrated
Voltage
AC 100/230 V (50/60 Hz)
55.14 cm x 22.1 cm x 40.04 cm
3.58 kg
Environmental Standards
ENERGY STAR Qualified
Plug and Play, TUV GS, FCC, RoHS, TUV Bauart, EAC
3-year warranty
Display Type
Energy Class
Class E
Diagonal Size
23.6"
Viewable Size
24"
Panel Type
MVA
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2715 mm
Brightness
250 cd/m²
Contrast Ratio
Vertical Refresh Rate
50 - 76 Hz
Horizontal Refresh Rate
30 - 83 kHz
Video Bandwidth
165 MHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
WLED
Controls & Adjustments
Tilt
OSD Languages
Czech, Chinese (traditional), Chinese (simplified), English, German, French, Italian, Portuguese, Finnish, Swedish, Russian, Spanish, Dutch, Japanese, Korean
HDCP, i-Menu, e-Saver technology, Screen+, i-Care
55.14 cm x 22.1 cm x 40.04 cm - with stand
3.58 kg
Audio
Speakers - stereo - integrated
VGA , 2 x HDMI , Headphones
Mechanical
Tilt Angle
-5/+25
VESA Mounting Interface
100 x 100 mm
VESA interface support
1 x VGA cable , 1 x HDMI cable , 1 x power cable
Power Supply
Internal
Input Voltage
17.4 kWh/1000h
Power Consumption (Typical)
17.96 watt
Power Consumption Stand by
0.5 watt
Power Consumption Sleep
0.19 watt
Power Consumption (Off Mode)
0.3 watt
Sustainability Information
ENERGY STAR Certified
Limited warranty - 3 years
