This all around top performer is the ideal solution for a variety of business settings. The 21.5-inch E2275PWJ delivers rich, vivid imagery in Full HD (1920x1080) resolution, plus offers fast 2ms response time to handle your most demanding applications. Integrated VGA, DVI and HDMI connectors make it easy to hook up a computer, laptop and a range of other devices. The built-in speakers and headphone jack provide extra convenience for online calls and more. To ensure you work in comfort, the ergonomic stand easily adjusts to a variety of positions (including pivot mode) and Flicker Free technology helps reduce eye fatigue.
Adjustable comfort
With height, pivot, swivel, and tilt adjustments, the AOC Pro-line E2275PWJ offers a customizable viewing experience tailored to your workspace needs, enhancing comfort and productivity. -
Vivid visuals
Experience true-to-life colors with a 21.5-inch display that supports 16.7 million colors and a dynamic contrast ratio, ensuring deep blacks and bright whites for a more immersive viewing experience. -
Seamless connectivity
Equipped with HDMI, DVI, and VGA interfaces, this monitor provides versatile connectivity options, allowing you to easily connect to a wide range of devices without the need for multiple adapters. -
Eco-friendly design
ENERGY STAR certified, the AOC Pro-line E2275PWJ is designed with energy efficiency in mind, featuring a low power consumption of just 19 W during typical operation, making it a smart choice for the environmentally conscious consumer.
- AOC Pro-line E2275PWJ - LED monitor - Full HD (1080p) - 21.5"
- LED-backlit LCD monitor - 21.5"
- Energy Class
- Class B
- Energy Consumption per Year
- 32 kWh
- Power Consumption (On mode)
- 22 W
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080 at 60 Hz
- Pixel Pitch
- 0.248 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1 / 200000000:1 (dynamic)
- Response Time
- 2 ms
- Colour Support
- 16.7 million colours
- Input Connectors
- HDMI, DVI, VGA
- Height, pivot (rotation), swivel, tilt
- Voltage
- AC 120/230 V (50/60 Hz)
- Black
- 50.4 cm x 21.29 cm x 46.88 cm
- 4.8 kg
- Environmental Standards
- ENERGY STAR Qualified
- Plug and Play, TUV GS, FCC, RoHS, TUV Bauart, EAC
- 3-year warranty
- Display Type
- Energy Class
- Class B
- 32 kWh
- Diagonal Size
- 21.5"
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.248 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- Colour Support
- Response Time
- 2 ms
- Vertical Refresh Rate
- 55 - 75 Hz
- Horizontal Refresh Rate
- 30 - 83 kHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 170
- Backlight Technology
- WLED
- HDCP, i-Menu, e-Saver technology, Flicker Free technology
- Black
- 50.4 cm x 21.29 cm x 46.88 cm - with stand
- 4.8 kg
Audio
- Speakers
- Output Power / Channel
- 2 Watt
- DVI , HDMI , VGA
Mechanical
- Tilt Angle
- -5/+25
- Height Adjustment
- 130 mm
- VESA Mounting Interface
- 100 x 100 mm
- Security lock slot (cable lock sold separately), wall mountable
- Included Accessories
- Stand
- Cables Included
- 1 x VGA cable , 1 x DVI cable , 1 x audio cable
- Security Slot Type
- Kensington security slot
- Input Voltage
- 22 W
- Power Consumption (Typical)
- 19 Watt
- Power Consumption Stand by
- 0.5 Watt
- 0.3 Watt
- On / Off Switch
Sustainability Information
- ENERGY STAR Certified
- Limited warranty - 3 years
