AOC's 27B2AM is equipped with a 27", Full HD VA panel with true-to-life colours. VGA and HDMI connections offer flexibility in source devices. The 27B2AM is a good contender for multi-monitor setups thanks to VESA mount support, 3-side borderless design and wide viewing angles. Plus, it is equipped with LowBlue and FlickerFree technologies.
Frameless design
Besides looking modern and attractive, frameless designs enable seamless multi-monitor setups. Your cursor/windows will not be lost anymore in the dark abyss of bezels, when many displays are placed side by side. -
FHD Resolution
Want to watch a Blu-ray movie in full quality, enjoy games in high resolution or read crisp text in office applications? Thanks to its Full HD resolution of 1920 x 1080 pixels, this monitor lets you do just that. Whatever you are viewing, with Full HD it will be displayed in rich detail without requiring a high-end graphics card or consuming a lot of your system's resources. -
VA Panel
VA Panels (Vertical Alignment) display deeper blacks and a high contrast for extra vivid and bright images. -
Low Blue Light
AOC Lowblue Light protects you from harmful blue light which, during long sessions, has been shown to cause eye strain, headaches, and sleeping disorders. Our Lowblue Light feature reduces the harmful wavelengths emitted without sacrificing colour composition, setting the experience free from the worry of eye damage. -
Flicker Free
AOC Flicker-Free Technology utilises a DC (Direct Current) backlight panel, reducing flickering light levels. With eye strain and fatigue absolutely minimised, feel free to enjoy those long, intense gaming sessions in comfort!
- AOC 27B2AM - LED monitor - Full HD (1080p) - 27"
- LED-backlit LCD monitor - 27"
- Energy Label QR Code URL
- Https://eprel.ec.europa.eu/qr/392123
- Energy Class
- Class E
- Power Consumption (On mode)
- 20 W
- Panel Type
- VA
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080 at 75 Hz
- Pixel Pitch
- 0.3114 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 4000:1 / 20000000:1 (dynamic)
- Response Time
- 4 ms (grey-to-grey)
- Colour Support
- 16.7 million colours
- Input Connectors
- HDMI, VGA
- Tilt
- Screen Coating
- 3H Hard Coating
- Voltage
- AC 120/230 V (50/60 Hz)
- Black
- 54.01 cm x 18.68 cm x 41.98 cm
- 3.6 kg
- REACH, TUV Bauart, EAC, ISO 9241-307 Class 1
- 3-year warranty
- Display Type
- Energy Class
- Class E
- Diagonal Size
- 27"
- Panel Type
- VA
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.3114 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- Colour Support
- Response Time
- Vertical Refresh Rate
- 50 - 76 Hz
- Horizontal Refresh Rate
- 30 - 83 kHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- 3H Hard Coating
- Backlight Technology
- WLED
- OSD Languages
- Multilingual
- Flicker Free technology, Wide Viewing Angle, Low Blue Light technology, 3-sided bezeless
- Black
- 54.01 cm x 18.68 cm x 41.98 cm - with stand
- 3.6 kg
- VGA , HDMI , Audio line-in , Headphones
Mechanical
- Tilt
- Tilt Angle
- -5/+20
- VESA Mounting Interface
- 100 x 100 mm
- Cables Included
- 1 x HDMI cable - 1.5 m
- MTBF
- 50,000 hour(s)
- Input Voltage
- 20 W
- Power Consumption SDR (On mode)
- 20 kWh/1000h
- Power Consumption Stand by
- 0.5 Watt
- 0.3 Watt
- Dimensions & Weight Details
- With stand - width: 54.01 cm - depth: 18.68 cm - height: 41.98 cm - weight: 3.6 kg , Without stand - width: 61.214 cm - depth: 3.76 cm - height: 36.139 cm
- Shipping Width
- 49.2 cm
- Shipping Depth
- 13.1 cm
- Shipping Height
- 61.4 cm
- Shipping Weight
- 5.5 kg
- Limited warranty - 3 years
