AOC 22P1 LED monitor 21.5"1920 x 1080 2ms HDMI VGA DVI
Quicklinx: G93QWS00 Mfr#: 22P1
Experience deep contrast with the 22P1! Its Full HD panel offers wide viewing angles. Connect any source with VGA, DVI, HDMI, DisplayPort inputs.
  • Display Port
    The most recent display interface standard from VESA, DisplayPort can also transfer audio, USB and other forms of data. DisplayPort version 1.2-1.2a support up to 165 Hz@1440p, 75 Hz@2160p, version 1.3 supports up to 240Hz@1440p, 120 Hz@2160p and the version 1.4 supports HDR10 specifications.
  • Integrated Speakers
    Built-in speakers make it easy to catch up with family, friends and colleagues. For movies, music, games and more, you'll enjoy quality audio without the hassle of connecting external speakers.
  • Height adjustable stand
    Raise or lower the screen to suit each individual's height and seating preferences. The easy-to-adjust stand ensures hours of working comfort.
  • MVA Panel
    The MVA (Multi-Domain Vertical Alignment) panel displays deeper blacks and a -high contrast for extra vivid and bright images.
AOC 22P1 - LED monitor - Full HD (1080p) - 21.5"
LED-backlit LCD monitor - 21.5"
Energy Label QR Code URL
Https://eprel.ec.europa.eu/qr/405241
Energy Class
Class E
Power Consumption (On mode)
15.4 W
Panel Type
MVA
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.24795 mm
Brightness
250 cd/m²
Contrast Ratio
3000:1 / 50000000:1 (dynamic)
Colour Support
16.7 million colours
Input Connectors
HDMI, DVI, DisplayPort, VGA
Display Position Adjustments
Screen Coating
Matte
Voltage
50.4 cm x 19.9 cm x 50.6 cm
Environmental Standards
TCO Certified Displays 8
TUV GS, GOST, RoHS, REACH, DisplayPort 1.2, ISPO
3-year warranty
Display Type
Energy Class
Class E
Diagonal Size
21.5"
Viewable Size
22"
Panel Type
MVA
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.24795 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Matte
Backlight Technology
WLED
50.4 cm x 19.9 cm x 50.6 cm - with stand
Audio
Speakers - stereo
Output Power / Channel
2 Watt
VGA , HDMI , DisplayPort , DVI , Headphones , 4 x USB 3.0
Mechanical
Tilt Angle
-3.5/+21.5
Swivel Angle
175
Height Adjustment
130 mm
1 x HDMI cable , 1 x DVI cable
MTBF
50,000 hour(s)
Input Voltage
15.4 W
15.4 kWh/1000h
Power Consumption (Typical)
20 Watt
Power Consumption Stand by
0.3 Watt
Power Consumption (Off Mode)
0.3 Watt
Shipping Width
71.5 cm
Shipping Depth
15.9 cm
Shipping Height
38.7 cm
Shipping Weight
6.2 kg
Sustainability Information
TCO Certified
Limited warranty - 3 years
