AOC 22" LED - HDMI - VGA - DVI - 2ms Monitor
Quicklinx: 7YS7WS00 Mfr#: E2250Swh
  • High-Definition Multimedia Interface (HDMI)
Display specialist AOC e2250Swh sets a course for both office and home with the 50 ID. The slim widescreen come in a great design. Thanks to numerous features the display equipped with LED backlights impress with very good image quality.
  • Powerful all-rounder
    AOC e2250Swh is characterized by a classic design. The monitor render even the fast movie sequences fluently and razor-sharp. And available with digital inputs, the large versions offer full HD resolution. Settings can be adjusted comfortably via the user friendly onscreen menu.
  • Slim and classic design
    At its slim region, the monitor which sport hairline textures on the rear side as well as the base, is just 1.6 cm deep. With the good look, you can easily fit into almost every setting.
  • Focus on the environment with LED technology
    Resource-efficiency and energy saving are of high importance at AOC. Thanks to the electricity-saving LED backlight technology, the monitor is manufactured entirely mercury-free. Users can individually contribute to an even low overall consumption.
AOC e2250Swh - LED monitor - Full HD (1080p) - 21.5"
LED-backlit LCD monitor - 21.5"
Energy Class
Class B
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.248 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 20000000:1 (dynamic)
Response Time
2 ms
Colour Support
16.7 million colours
Input Connectors
HDMI, DVI-D, VGA
Speakers
Integrated
Display Position Adjustments
Tilt
Voltage
51.1 cm x 4.9 cm x 33.4 cm
3.3 kg
Environmental Standards
ENERGY STAR Qualified
TUV GS, BSMI, GOST, DDC-1, DDC-2B, TUV S, CB, FCC, DDC/CI, RoHS, KCC, J-MOSS, E-Standby, ISO 9024-307
3-year warranty
Display Type
Energy Class
Class B
Diagonal Size
21.5"
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.248 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
2 ms
Vertical Refresh Rate
83 Hz
Horizontal Refresh Rate
75 kHz
Video Bandwidth
148.5 MHz
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Backlight Technology
WLED
Controls & Adjustments
Volume
Power off timer, HDCP, Eco-Mode, i-Menu, e-Saver technology
3.3 kg
Audio
Speakers - integrated
VGA , DVI-D , HDMI
Mechanical
Tilt
Tilt Angle
-4/+17
VESA Mounting Interface
75 x 75 mm
Security lock slot (cable lock sold separately), wall mountable
1 x VGA cable , 1 x audio cable
Input Voltage
Power Consumption (Typical)
31 Watt
Power Consumption Stand by / Sleep
0.5 Watt
Included Software
Drivers & Utilities
Microsoft Windows 7
Sustainability Information
ENERGY STAR Certified
Limited warranty - 3 years
