Highlights of the AOC 18.5" widescreen 931SWL monitor
Screen: 18.5" widescreen (1366 x 768)
Brightness: 200 cd/m2
Dynamic Contrast Ratio: 10000:1
Response time: 5ms
Connectivity: D-sub
Aspect Ratio: 16:9
VESA Wall mountable (100mm x 100mm)
3 years warranty
- AOC 931Swl - LCD monitor - 18.5"
- Aspect Ratio
- 16:9
- Native Resolution
- 1366 x 768 at 60 Hz
- Pixel Pitch
- 0.3 mm
- Brightness
- 200 cd/m²
- Contrast Ratio
- 1000:1 / 10000:1 (dynamic)
- Response Time
- 5 ms
- Colour Support
- 16.7 million colours
- Input Connectors
- VGA
- Tilt
- Screen Coating
- Anti-glare, hard coating
- Voltage
- AC 120/230 V (50/60 Hz)
- Piano black
- 45.5 cm x 22 cm x 35.8 cm
- 3.9 kg
- Environmental Standards
- ENERGY STAR Qualified
- Plug and Play, TUV, cUL, DDC-2B, DDC-2Bi, TUV S, CCC, FCC, RoHS
- 3-year warranty
- Display Type
- LCD monitor / TFT active matrix
- Diagonal Size
- 18.5"
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.3 mm
- Brightness
- 200 cd/m²
- Contrast Ratio
- Colour Support
- Response Time
- 5 ms
- Vertical Refresh Rate
- 75 Hz
- Horizontal Refresh Rate
- 80 kHz
- Video Bandwidth
- 85.5 MHz
- Horizontal Viewing Angle
- 90
- Vertical Viewing Angle
- 50
- Screen Coating
- Eco-Mode, anti-glare
- Piano black
- 3.9 kg
- VGA
Mechanical
- Tilt
- Tilt Angle
- 25
- VESA Mounting Interface
- 100 x 100 mm
- Power Supply
- Internal
- Input Voltage
- Power Consumption (Typical)
- 25 Watt
- Power Consumption Stand by / Sleep
- 1 Watt
Sustainability Information
- ENERGY STAR Certified
- Limited warranty - parts and labour - 3 years
