The VP600P is crafted for quality, performance and incredible value. This entry-level solution gives you everything you need in a power supply. No twinkly lights or glittery paint jobs - a 120 mm fan for effective and quiet cooling, dual +12 V rails for amazingly stable power and heavy-duty protection circuitry for peace of mind, no matter how demanding your system. All the features, none of the waste: for builders that are strictly business, the VP600P is strictly power.
Efficient cooling
Equipped with a 120 mm fan, this power supply ensures efficient cooling, maintaining optimal performance even under heavy loads. -
High compatibility
Designed for PC/Server use, this power supply supports a wide range of systems with its 24 pin ATX and 8 pin EPS12V connectors, including detachable sections for versatile connectivity. -
Reliable power output
With a power output of 600 W and an efficiency rate of 88%, this power supply delivers reliable and efficient energy to your system's components. -
Comprehensive safety standards
Meets multiple safety and environmental standards, including CB, CCC, ErP Lot 6, RCM, RoHS, S Mark, and TUV, ensuring a safe and sustainable power solution.
- Antec VP600P - power supply - 600 Watt
- Power supply - internal
- 1.6 kg
- Localisation
- United Kingdom
- Input Voltage
- AC 230 V
- Power Capacity
- 600 Watt
- Output Current
- +5V - 20 A , +3.3V - 20 A , +12V1 - 30 A , +12V2 - 30 A , -12V - 0.5 A , +5VSB - 3 A
- Output connectors
- 1 x power 24 pin ATX with detachable 4 pin section , 1 x power 8 pin EPS12V with detachable 4 pin ATX12V section , 4 x 4 PIN internal power , 5 x 15 pin Serial ATA power , 2 x 8 pin PCI Express power with detachable 2 pin section , 1 x 4 PIN mini-power connector
- Cooling System
- 120 mm fan
- 15 cm x 14 cm x 8.6 cm
- 2-year warranty
- Localisation
- United Kingdom
- Input Voltage
- AC 230 V
- Frequency Required
- 50 - 60 Hz
- Power Output Connectors Details
- Max Electric Current
- 4.5 A
- Power Capacity
- 600 Watt
- Output Current
- Efficiency
- 88%
- Cooling System
- 120 mm fan
- Thermal monitoring, short-circuit protection
- TUV, CB, CCC, RoHS, GOST-R, S Mark, Energy-Related Products (ErP) Lot 6, RCM
- Limited warranty - 2 years
- 15 cm
- 14 cm
- 8.6 cm
- 1.6 kg
