Antec TriCool 9.2cm Clear Case Fan 3 Speed 3-pin with 4-pin Adapt
Quicklinx: 9PJYWS00 Mfr#: 0-761345-75092-9
Antec TriCool 0761345-75092-9 balances necessary cooling with quietness.
Antec TriCool - case fan
Case fan
Fan Diameter
92 mm
Fan Height
25.4 mm
Rotation Speed
1200/1600/2200 rpm
Air Flow
21/28/38 cfm
Power Connector
3-pin plug, 4 pin Molex connector
Variable fan speed
9.2 cm x 9.2 cm x 2.54 cm
Fan speed monitoring
Case fan
9.2 cm
9.2 cm
2.54 cm
Heatsink & Fan
Fan Diameter
92 mm
Fan Height
25.4 mm
Rotation Speed
1200/1600/2200 rpm
Air Flow
21/28/38 cfm
Power Connector
Variable fan speed
RoHS
Sound Emission
14.6 dBA
