Antec's Spot Cool fans provide your component of choice with a smart, targeted cooling solution. Specifically designed to mount on any motherboard, Spot Cool delivers precise cooling with its easy-bend arm and rotatable head, and it makes a flashy addition to any enclosure with its LED fan. Simply mount it using any motherboard mounting screw, angle the fan as you desire and power it from a motherboard fan connector. Get active cooling for your RAM, chipset, graphics cards or wherever your system needs it, and you'll see even better performance and a longer product lifespan. Spot Cool: cooling right where you need it.
- Antec Spot Cool 100 - case fan
- Product Type
- Case fan
- Rotation Speed
- 1000-2000 rpm
- Air Flow
- 4.9 - 9.8 cfm
- Noise Level
- 16 - 24.8 dBA
- Variable fan speed, blue LEDs
- 13.7 cm x 1.6 cm x 26 cm
- 99 g
- Product Type
- Case fan
- 13.7 cm
- 1.6 cm
- 26 cm
- 99 g
Heatsink & Fan
- Rotation Speed
- 1000-2000 rpm
- Air Flow
- 4.9 - 9.8 cfm
- Air Pressure
- 0.2-0.9 mm
- Noise Level
- 16 - 24.8 dBA
- RoHS
