Realize your data transfer potential with the incredibly versatile and easy-to-use MX-25, the portable 2.5" hard drive enclosure. With a dual USB 2.0 and eSATA interface and 3-head USB cable, the extremely lightweight MX-25 supports SATA hard drives up to 500GB without breaking a sweat. No external power adapter is required, simply install your drive, connect it to your computer, and start transferring data at up to 480Mbps and 3Gbps, respectively. Make life easier for you and your data with the MX-25, the smaller, more versatile 2.5" hard drive enclosure.
- Antec VERIS MX-25 - storage enclosure - SATA 3Gb/s - eSATA 3Gb/s, USB 2.0
- Storage enclosure - external
- Bus Type
- Localisation
- Europe
- Expansion Bays
- 1 x internal - 2.5"
- Hard Drive Form Factor Compatibility
- 2.5"
- Interface
- SATA 3Gb/s
- Data Transfer Rate
- 3 Gbit/s
- Supported Devices
- Hard drive
- Power Source
- Optional AC adapter
- System Requirements
- Microsoft Windows 2000, Apple MacOS X, Microsoft Windows XP, Microsoft Windows Vista
- 8.2 cm x 1.8 cm x 13.4 cm
- 191 g
- 3-year warranty
- 2.5"
- Host Bus
- Localisation
- Europe
Storage Controller
- Interface
- SATA 3Gb/s
- 3 Gbit/s
- Supported Devices
- Hard drive
- Processor
- No CPU
- Bays
- 1 x SATA 3Gb/s - SATA
- Connections
- 1 x USB 2.0 - 4 pin USB Type B , 1 storage - eSATA-300
- Cables Included
- 1 x USB cable - external
- RoHS
- Power Source
- OS Required
- Limited warranty - 3 years
- 8.2 cm
- 1.8 cm
- 13.4 cm
- 191 g
