The Antec KÜHLER H2O 920 provides maximum-performance liquid cooling for your CPU in a quick, easy-to-install package. Unlike traditional liquid cooling systems, this self-contained unit comes prefilled and requires zero maintenance. The dual 120 mm Pulse Width Modulation (PWM) fans and 3rd generation copper coldplate ensure quiet, efficient cooling, while the 49 mm thick radiator is equipped to handle the highest performing CPUs on the market. Lastly, the included software helps you monitor and control the KÜHLER H2O 920's performance and allows you to customize its stylish RGB LED. Designed to unlock the maximum potential of your CPU, the Antec KÜHLER H2O 920 delivers exceptional cooling when you need it the most.
Please note that the Kuhler range are no longer compatible with S775
- CPU Socket Compatibility: Intel LGA 1155 / 1156 / 1366, AMD AM2 / AM3 / AM2+ / AM3+
- Included software provides essential tools to control and monitor the KÜHLER H2O 920
- Non-corrugated easy-bend tubes for maximum flexibility in radiator positioning
- Pulse Width Modulation (PWM) radiator fans generate the quietest high performance cooling
- Customizable RGB LED creates brilliant illumination
- Cooling Liquid - Safe, environmentally-friendly, anti-corrosive
- Fan Speed: 700 - 2400 RPM (PWM controlled)
- Tubing Length: 13.0" / 330 mm
- Radiator Dimensions: 5.6" (H) x 4.7" (W) x 1.9" (D) / 151 mm (H) x 120 mm (W) x 49 mm (D)
- Fan Dimensions: 4.7" x 1.0" / 120 mm x 25 mm
- Air Flow: 110.0 CFM
- Noise Level: 43 dBA
- Cold Plate + Pump Height: 1.1" / 29 mm
- AQ3 - Antec Quality 3 year limited warranty on parts and labor
- Antec KÜHLER H2O 920 - liquid cooling system CPU heat exchanger with integrated pump
- Product Type
- Liquid cooling system CPU heat exchanger with integrated pump
- Compatibility
- LGA775 Socket, LGA1156 Socket, Socket AM2, Socket AM2+, LGA1366 Socket, Socket AM3, LGA1155 Socket
- Heatsink Material
- Copper
- Fan Diameter
- 120 mm
- Fan Height
- 25 mm
- Rotation Speed
- 700-2400 rpm
- Air Flow
- 110 cfm
- Noise Level
- 27.4 dBA
- Power Connector
- 4-pin fan connector
- Variable fan speed
- 1.1 kg
- 3-year warranty
- Product Type
- 1.1 kg
Heatsink & Fan
- Compatible With
- Heatsink Material
- Copper
- Heatsink Dimensions
- 151 mm x 120 mm x 49 mm
- Fan Diameter
- 120 mm
- Fan Height
- 25 mm
- Rotation Speed
- 700-2400 rpm
- Air Flow
- 110 cfm
- Noise Level
- 27.4 dBA
- Power Connector
- RoHS
- Limited warranty: - 3 years
