The Antec KÜHLER H2O 1250 provides maximum-performance liquid cooling for your CPU and delivers best-in-class performance in a quick, easy-to-install package. Unlike traditional liquid cooling systems, this self-contained unit comes prefilled and requires no maintenance. Two 120 mm voltage-controlled (PWM) fans and dual extra large pumps ensure quiet, efficient cooling, while the 240 mm radiator maximizes cooling surface area to dissipate heat from the high performance CPUs. Designed to unlock the maximum potential of your CPU, the Antec KÜHLER H2O 1250 delivers exceptional cooling when you need it the most.
Efficient cooling
The Antec KÜHLER H2O 1250 liquid cooling system CPU heat exchanger with integrated pump offers efficient cooling for a wide range of sockets including LGA1150, LGA1155, LGA1156, LGA1366, LGA2011, LGA775, Socket AM2, AM2+, AM3, AM3+, FM1, and FM2. Its copper heatsink and dual 120 mm PWM support fans ensure optimal heat dissipation. -
Versatile compatibility
Designed for versatility, this cooling system is compatible with a broad spectrum of sockets, making it a suitable choice for various PC builds. Whether upgrading an existing setup or building a new one, its wide compatibility ensures seamless integration. -
Enhanced performance
With a fan rotation speed ranging from 600 to 2400 rpm, the Antec KÜHLER H2O 1250 provides precise control over cooling performance. This adaptability ensures that your system remains cool under different operational loads, enhancing overall performance. -
Aesthetic LED lighting
Beyond performance, this cooling system features LED lighting, adding a stylish aesthetic to your PC build. The lighting not only enhances the visual appeal of your setup but also allows for a personalized touch to your system.
- Antec KÜHLER H2O 1250 - liquid cooling system CPU heat exchanger with integrated pump
- Product Type
- Liquid cooling system CPU heat exchanger with integrated pump
- Compatibility
- LGA775 Socket, LGA1156 Socket, Socket AM2, Socket AM2+, LGA1366 Socket, Socket AM3, LGA1155 Socket, Socket AM3+, LGA2011 Socket, Socket FM1, Socket FM2, LGA1150 Socket
- Heatsink Material
- Copper
- Fans Qty
- Dual
- Fan Diameter
- 120 mm
- Fan Height
- 25 mm
- Rotation Speed
- 600-2400 rpm
- Pulse-width modulation (PWM) support
- 1.3 kg
- LED lighting
- 3-year warranty
- Product Type
- 1.3 kg
Heatsink & Fan
- Compatible With
- Heatsink Material
- Copper
- Heatsink Dimensions
- 280 mm x 120 mm x 27 mm
- Fans Qty
- 2
- Fan Diameter
- 120 mm
- Fan Height
- 25 mm
- Rotation Speed
- 600-2400 rpm
- LED lighting
- RoHS
- Limited warranty: - 3 years
