Combat heat with Antec’s C400 CPU Cooler. Designed for leading Intel and AMD processors, the C400 CPU Cooler supports Intel® Core™ i7 Extreme, and AMD™ Sempron, among others. The 8 mm thick copper coldplate and nickel-plated aluminum fins with four embedded heatpipes achieve maximum heat transference as well as lightweight durability. And with the stealthily quiet blue LED PWM (pulse width modulation) fan, the C400 CPU Cooler is the perfect tool to combat heat when overclocking your processor.
HIGH STATIC PRESSURE LED FAN
Quiet, 120 mm LED PWM fan with 77 CFM of airflow illuminates your rig with blue light
STRAIGHT TOUCH TECHNOLOGY
The 8mm thick copper coldplate and four copper heatpipes with Straight Touch technology quickly transfer heat away from your CPU
UNIQUE HEATSINK DESIGN
Two-tiered fin structure dissipates heat efficiently, while aluminum oxide coating prevents oxidation
BROAD SOCKET COMPATIBILITY
Compatibility with the newest Intel and AMD platforms, and the push-pin mounting system
and included gold thermal paste make for a fast, simple installation
High static pressure LED fan
Quiet, 120 mm LED PWM fan with 77 CFM of airflow illuminates your rig with blue light. -
Straight touch technology
The 8mm thick copper cold plate and four copper heatpipes with Straight Touch technology quickly transfer heat away from your CPU. -
Unique heatsink design
Two-tiered fin structure dissipates heat efficiently, while aluminum oxide coating prevents oxidation. -
Broad socket compatibility
Compatibility with the newest Intel and AMD platforms, and the push-pin mounting system and included gold thermal paste make for a fast, simple installation.
- Antec C400 - processor cooler
- Product Type
- Processor cooler
- Package Content
- Thermal paste
- Compatibility
- LGA775 Socket, LGA1156 Socket, Socket AM2, Socket AM2+, Socket AM3, LGA1155 Socket, Socket AM3+, Socket FM1, Socket FM2, LGA1150 Socket, Socket FM2+, LGA1151 Socket
- Heatsink Material
- Aluminium
- Fan Diameter
- 120 mm
- Fan Height
- 25 mm
- Fan Bearing
- Rifle bearing
- Rotation Speed
- 800-1900 rpm
- Air Flow
- 77 cfm
- Noise Level
- 20.3 - 34.5 dBA
- Power Connector
- 4-pin fan connector
- Pulse-width modulation (PWM) support, 4 copper heatpipes, blue LED
- 15.5 cm x 12.5 cm x 7.6 cm
- 830 g
- 3-year warranty
- Product Type
- Processor cooler
- Package Content
- Thermal paste
- 15.5 cm
- 12.5 cm
- 7.6 cm
- 830 g
Heatsink & Fan
- Compatible With
- Heatsink Material
- Aluminium
- Fan Diameter
- 120 mm
- Fan Height
- 25 mm
- Fan Bearing
- Rifle bearing
- Rotation Speed
- 800-1900 rpm
- Air Flow
- 77 cfm
- Noise Level
- 20.3 - 34.5 dBA
- Power Connector
- Limited warranty: - 3 years
