Antec C40 Nickel-Plated Quad Direct Contact CPU Air-Cooler
Quicklinx: CK38WS00 Mfr#: 0-761345-10929-1
Defeat heat created by your processor and allow for improved operation with Antec CPU coolers flow. Designed for compatibility with leading desktop processor sockets, all four CPU coolers supports Intel Core i7, Core i5, Core i3 and AMD Phenom II, among others. This high-performance CPU cooler features a whisper-quiet liquid state bearing fan that works with your case s airflow to effectively force out heat created by your processor and rubber fan grommets to reduce vibration.
Antec C40 - processor cooler
Processor cooler
Compatibility
LGA775 Socket, LGA1156 Socket, Socket AM2, Socket AM2+, LGA1366 Socket, Socket AM3, LGA1155 Socket, Socket FM1
Heatsink Material
Copper
Fan Diameter
92 mm
Fan Bearing
Liquid state bearing
Rotation Speed
800-1600 rpm
Air Flow
19-38 cfm
Noise Level
10 - 22 dBA
Heat pipe technology
10.1 cm x 7.6 cm x 13.1 cm
600 g
Processor cooler
10.1 cm
7.6 cm
13.1 cm
600 g
Heatsink & Fan
Compatible With
Heatsink Material
Copper
Fan Diameter
92 mm
Fan Bearing
Rotation Speed
800-1600 rpm
Air Flow
19-38 cfm
Noise Level
10 - 22 dBA
