Antec A40 PRO. Suitable for: Processor, Type: Cooler, Fan diameter: 9.2 cm. Width: 100 mm, Depth: 75 mm, Height: 136 mm
Silent LED fan
Whisper-quiet, 92mm blue LED PWM fan. -
Four high performance heatpipes
Straight Touch copper coated heatpipes provide full contact to the CPU, for more efficient heat transference. -
Thermal conductive coating
Aluminum oxide coating on the top fin boosts the efficiency of heat transfer and prevents oxidation. -
Universal socket compatibility
Compatibility with Intel and AMD platforms, and the push-pin mounting system and included thermal paste make for a fast, simple installation.
- Antec A40 PRO - processor cooler
- Product Type
- Processor cooler
- Package Content
- Thermal paste
- Compatibility
- LGA775 Socket, LGA1156 Socket, Socket AM2, Socket AM2+, Socket AM3, LGA1155 Socket, Socket AM3+, Socket FM1, Socket FM2, LGA1150 Socket, Socket FM2+, LGA1151 Socket
- Heatsink Material
- Aluminium
- Fan Diameter
- 92 mm
- Fan Height
- 25 mm
- Fan Bearing
- Fluid dynamic bearing
- Rotation Speed
- 800-2200 rpm
- Air Flow
- 38 cfm
- Noise Level
- 16 - 23 dBA
- Power Connector
- 4-pin fan connector
- 4 copper heatpipes, blue LED
- 10 cm x 13.6 cm x 7.5 cm
- 570 g
- 3-year warranty
- Product Type
- Processor cooler
- Package Content
- Thermal paste
- 10 cm
- 13.6 cm
- 7.5 cm
- 570 g
Heatsink & Fan
- Compatible With
- Heatsink Material
- Aluminium
- Fan Diameter
- 92 mm
- Fan Height
- 25 mm
- Fan Bearing
- Rotation Speed
- 800-2200 rpm
- Air Flow
- 38 cfm
- Noise Level
- 16 - 23 dBA
- Power Connector
- Limited warranty: - 3 years
