Antec 650W EDGE 80+ Gold PSU
Quicklinx: 9S3VWS00 Mfr#: 0-761345-05066-1
Antec's EDGE series is the pinnacle of power supplies. EDGE is fully modular with a revolutionary 18+10-pin MBU socket for the needs of tomorrow. By using a PSU that is 80 PLUS® GOLD & ErP Lot 6: 2013 certified, operating up to 92% efficient, you can reduce your electricity bill by up to 20% when compared to many other power supplies. EDGE's innovative 16-pin sockets create a new level of flexibility by doubling the modular connectivity, supporting two different 8-pins connectors and even future connectors of 10, 12, 14 or 16-pins. All cables are darkened and also flat (except MBU cable) to become Flat Stealth Wires and are thus nearly invisible in your chassis. 2 High Current Rails and a ~99% +12V output ratio maximize EDGE's capabilities to power the latest CPU's & GPU's. CircuitShield™ makes EDGE safe and reliable in any environment with its 7 industrial-grade protections. Backed by a 5 year warranty and lifetime global 24/7 support, EDGE embodies everything a power supply can accomplish today.
  • 650W Continuous Power - Guaranteed 650W of Continuous Power from Antec
  • 80 PLUS® GOLD certified - Up to 92% efficient, to reduce your electricity bill
  • AQ5 - Antec Quality 5 year warranty and lifetime global 24/7 support
  • 16-pin Socket - Industry-leading 16-pin sockets double the modular connectivity by supporting 2 different 8-pin cables per socket and allow for future connector changes
  • 135 mm LED FDB Silence - Whisper-quiet high-quality LED fluid-dynamic bearing fan with long lifetime
  • Thermal Manager - An advanced low voltage fan control for optimal heat & noise management
  • High Current Rails - 2 +12V rails with high load capabilities ensure maximum CPU & GPU compatibility
  • 99.7% +12V - Output for maximum CPU & GPU support
  • 28(18+10)-pin MBU socket - For possible future MBU connectors
  • CircuitShield™ - Full suite of industrial grade protections: Over Current Protection (OCP), Over Voltage Protection (OVP), No Load Operation (NLO), Short Circuit Protection (SCP), Over Power Protection (OPP), Over Temperature Protection (OTP) & Surge & Inrush Protection (SIP)
  • Japanese Heavy-Duty Caps - High-performance Japanese capacitors ensure tightest DC stability and regulation
  • Flat Stealth Wires - Flat and darkened wires for minimal visibility in chassis (except MBU cable)
  • ATX12V 2.4 - Engineered according to the newest PSU guideline and compatible with the latest CPU generation
  • Less clutter, more room, better cooling
    The EDG650 is a fully modular PSU, this allows you to use only the cables you need, greatly simplifies installation and helps clear out space. This can also improve your airflow because excess cables can obstruct and reduce airflow. With the addition of Flat Stealth Wires, all wires are darkened for minimal visibility in the chassis, making your rig that much cleaner. With a silent - whisper-quiet high-quality 135 mm FDB (Fluid Dynamic Bearing) fan with long lifetime.
  • Silent computing
    Includes two red and black Anti-Noise De-Couplers to reduce vibration within the chassis.
Antec EDGE EDG650 - power supply - 650 Watt
Power supply - active Power Factor Correction (PFC) - internal
Specification Compliance
ATX12V 2.4/ EPS12V 2.92
80 PLUS Certification
80 PLUS Gold
1.8 kg
United Kingdom
Input Voltage
AC 100-240 V
Output Voltage
+3.3, +5, ±12 V
Power Capacity
650 Watt
Output Current
+3.3V - 20 A , +5V - 20 A , +12V1 - 35 A , +12V2 - 35 A , -12V - 0.3 A , +5VSB - 2.5 A
Output connectors
1 x power 24 pin ATX with detachable 4 pin section , 4 x 8 pin PCI Express power with detachable 2 pin section , 9 x 15 pin Serial ATA power , 6 x 4 PIN internal power , 1 x 4 PIN mini-power connector , 1 x power 8 pin EPS12V with detachable 4 pin ATX12V section
Modular Cable Management
Cooling System
135 mm fan
2 x red Anti-Noise De-Couplers, 2 x black Anti-Noise De-Couplers
15 cm x 17 cm x 8.6 cm
5-year warranty
PSU Form Factor
ATX
United Kingdom
Input Voltage
AC 100-240 V
Input Voltage Margin
± 10%
Frequency Required
50 - 60 Hz
Output Voltage
+3.3, +5, ±12 V
Power Capacity
650 Watt
Output Current
Efficiency
92%
80 PLUS Gold
MTBF
100,000 hours
Cooling System
135 mm fan
Overheat protection, over current protection, over voltage protection, overpower protection, dual 12V rails, short-circuit protection, surge & inrush protection, fan speed control, Intel 4th-gen CPU (Haswell) compatible, fluid dynamic bearing cooling fan, CircuitShield
TUV, BSMI, CB, CCC, FCC, RoHS, KCC, GOST-R, cTUVus, Energy-Related Products (ErP) Lot 6, RCM
Limited warranty - 5 years
50 °C
15 cm
17 cm
8.6 cm
1.8 kg
