Antec 450W Basiq VP450P ATX PSU
Quicklinx: 7TD7WS00 Mfr#: 0-761345-06451-4
The VP450P is crafted for quality, performance and incredible value. This entry-level solution gives you everything you need in a power supply. No twinkly lights or glittery paint jobs - a 120 mm fan for effective and quiet cooling, dual +12V rails for amazingly stable power, heavy-duty protection circuitry and active Power Factor Correction (PFC) that saves money on corporate power bills. And it comes with all the assurance of Antec's AQ2 Antec Quality 2 year limited warranty. All the features, none of the waste: for builders that are strictly business, the VP450P is strictly power.
  • 450 watts of Continuous Power
  • ATX12V version 2.3 compliant
  • Dual +12V rails ensure greater system stability
  • EuP 2010 compliant assuring efficiency and low standby power consumption
  • Active Power Factor Correction with PF: 0.99 for higher efficiency and less power grid pollution
  • 120 mm fan delivers quiet, reliable cooling
  • Black exterior complements any system
  • Heavy-duty protection circuitry prevents damage from a variety of dangers:
  • Over Current Protection (OCP)
  • Over Voltage Protection (OVP)
  • Short Circuit Protection (SCP)
  • Over Power Protection (OPP)
  • Safety: CB,TÜV,C-TICK,CCC,CE , Gost-R
  • MTBF: 100,000 hours
  • AQ2 Antec Quality 2 year limited warranty on parts and labor
  • Unit Dimensions: - 86mm (H) x 150mm (W) x 140mm (D) / 5.9" (H) x 5.9" (W) x 3.4" (D)
Antec Basiq VP450P - power supply - 450 Watt
Power supply - internal
United Kingdom
Input Voltage
AC 200-240 V
Power Capacity
450 Watt
Output Current
+5V - 15 A , +3.3V - 24 A , +12V1 - 18 A , +12V2 - 18 A , -12V - 0.8 A , +5VSB - 2.5 A
United Kingdom
Input Voltage
AC 200-240 V
Input Voltage Margin
± 10%
Frequency Required
50 - 60 Hz
Power Capacity
450 Watt
Output Current
Over current protection, over voltage protection, short-circuit protection
