Anker PowerWave 10 Dual Pad - White
Quicklinx: FXKRWS00 Mfr#: B2571K21
The Need for Speed: With 10W high-speed charging for Samsung Galaxy, and a 7.5W charging mode to refuel iPhones. The fastest possible wireless input that each can accept.
Two is better: charge 2 devices at once with dual pads twin charging surfaces.
Case friendly: Don't worry about taking your case off whenever you have to charge. PowerWave chargers deliver power directly through cases up to 5mm thick - including Otterboxes.
Anker PowerWave 10 Dual Pad wireless charging pad - + AC power adapter - 10 Watt
Wireless charging pad + AC power adapter
20.46 cm x 9.2 cm x 1.48 cm
185 g
White
12 V
Max Electric Current
3 A
Wireless Charging Standards
Qi
Power Provided
10 Watt
18 months warranty
Mobile phone
20.46 cm
9.2 cm
1.48 cm
185 g
Enclosure Colour
White
12 V
Power Provided
10 Watt
3 A
Wireless Charging
Qi
AC Power Adapter Included
LED indicator
Limited warranty - 18 months
