Brand
Anker PowerCore Wireless 10K
Quicklinx: FXKMWS00 Mfr#: A1615H11
Type: Wireless Charging
Product Range: Anker PowerCore
Product Model: 10000
Hurry, only 2 left in stock!
£37.49 ex VAT
£44.98 inc VAT
Marketing description is not available.
  • Charge multiple devices
    Charge your phone wirelessly while charging up to 2 other devices at the same time via dual USB ports.
  • Wireless pass-through charging
    When connected to the wall, PowerCore continues to provide wireless-charging to your Qi-enabled devices while recharging itself, so you can wake up to a fully charged phone and pad every morning.
  • Non-slip design
    Designed with a rubber coating that not only helps to keep your phone in place while charging but also feels great in your hand.
Anker PowerCore 10000 wireless power bank - USB - 12 Watt
Wireless power bank
60 mm x 92 mm x 22 mm
180 g
Output Connector Type
Total 2: USB - on cable: USB-C
Wireless Charging
Wireless Charging Standards
Qi
10000 mAh
Power Provided
12 Watt
Cables
USB-C to USB-A cable
18 months warranty
Wireless power bank
Tablet, mobile phone
60 mm
92 mm
22 mm
180 g
Enclosure Colour
Input Connectors
24 pin USB-C
Input Connectors Qty
1
Output connectors
Total 2: 4 pin USB Type A
Power Provided
12 Watt
Detachable Cable Connector Type
USB-C
Wireless Charging
Qi
10000 mAh
LED power meter
Carrying pouch
Qi
Limited warranty - 18 months
Brand: Anker
Stock Status: In stock
