Anker 533 Wireless Power Bank (PowerCore 10K)
The Freedom to Charge Anywhere
Wireless Charging. Anywhere.
The convenience of wireless charging is no longer confined to your home or office. Qi-certified charging up to 10W lets you fully charge an iPhone 11 in less than 4 hours no matter where you are.
Choose How You Charge
With wireless, USB, and USB-C charging all available, PowerCore gives you unprecedented choice over how you charge. You can even use all of them at once to charge 3 devices simultaneously.
High-Speed Charging
The 18W USB-C port offers the kind of charging speeds that you normally only find in a wall charger. Charge an iPhone 11 to 50% in 30 minutes or fully charge a Galaxy S20 in less than 2 hours.
Power a Full Day
PowerCore is equipped with a 10,000mAh cell capacity to keep your devices charged for at least a full day. Charge an iPhone 11 or Pixel 4 more than twice, or charge a Galaxy S20 over 1.5 times.
Universal Compatibility
Qi-certification offers flawless wireless charging with compatible devices, while our exclusive PowerIQ 3.0 technology ensures optimized charging to virtually any mobile device including phones, tablets, and more.
Built-In Phone Stand
Slide-out the built-in phone stand to watch videos while charging. Note: Only wired charging can be accessed while using the phone stand.
Rapid Recharge
Connect an 18W charger (not included) to the USB-C port to fully recharge the internal battery in just 4.5 hours.
Notes
- This wireless charger does not feature MagSafe-style magnetic alignment, and therefore is not able to charge the iPhone 12 series magnetically.
- The wireless charging feature does not work with the Apple Watch series or Samsung Watch series.
- Do not use a 5W charger to charge your phone wirelessly and recharge PowerCore simultaneously. To charge simultaneously at full speed, it’s recommended to use a charger with at least an 18W output.
- Phone cases thicker than 5 mm, magnetic attachments, metal attachments, stands, or credit cards will interfere with wireless charging.
- Place your phone on the center of the wireless pad to ensure stable charging. If your phone does not show as charging, adjust the position of your phone.
- Press the power button to activate wireless charging.
- 10,000 mAh is the total of the nominal rated capacity of internal battery cells.
Portable wireless charging
Qi-certified to provide up to 10W of wireless charging power to phones, earbuds, or other devices on the go. -
Desktop mode
Use PowerCore as a wireless pad by connecting to a power supply via the USB-C port. Charge your device wirelessly while giving PowerCore's internal battery a full recharge. -
High-speed USB charging
Connect to either the USB-C or USB-A port to give your phone or tablet a powerful charge.
- Anker PowerCore III 10K Wireless wireless power bank - USB, 24 pin USB-C - 18 Watt
- Product Type
- Wireless power bank
- Designed For
- Tablet, mobile phone, wireless earphones
- 6.84 cm x 15.18 cm x 1.87 cm
- 243 g
- Black fabric
- Output Connector Type
- Total 2: USB, 24 pin USB-C
- Fast Charge Technology
- Anker PowerIQ 3.0
- Wireless Charging
- Wireless Charging Standards
- Qi
- Battery
- 10000 mAh
- Power Provided
- 18 Watt
- Power Device Details
- - 4 pin USB Type A - 18 W , - 24 pin USB-C - 18 W
- Cables
- USB-C to USB-C cable
- 18 months warranty
- Product Type
- Designed For
- 6.84 cm
- 15.18 cm
- 1.87 cm
- 243 g
- Enclosure Colour
- Black fabric
- Input Connectors
- 24 pin USB-C
- Input Connectors Qty
- 1
- Output connectors
- Total 2: 4 pin USB Type A, 24 pin USB-C
- Power Provided
- 18 Watt
- 4 pin USB Type A - 18 W , 24 pin USB-C - 18 W
- Wireless Charging
- Qi
- Anker PowerIQ 3.0
- 10W wireless output, LED indicator, simultaneously charges up to 3 devices
- Capacity
- 10000 mAh
- Recharge Time
- 4.5 hour(s)
- Included Accessories
- Travel bag
- Cables Included
- Shipping Width
- 13 cm
- Shipping Depth
- 20 cm
- Shipping Height
- 3.5 cm
- Shipping Weight
- 390 g
- Limited warranty - 18 months
