- Prop It Up: Features a versatile built-in foldable kickstand that keeps your iPhone 13/12 upright for a comfortable viewing angle.
- Strong and Snappy: The super-strong magnet snaps magnetically into place to ensure perfect alignment and an efficient charge.
- Slim and Compact: The sleek and slim design is only 0.5 inch (12.8 mm) thin, so you can single-handedly take calls, selfies, and more.
- From Small to Smaller: Anker's new Mini Cell technology reduces the size of the overall battery without compromising power and charging efficiency.
- What You Get: Anker 622 Magnetic Battery (MagGo), 23.6 inch (60 cm) USB-C to USB-C cable, welcome guide, worry-free 24-month warranty, and friendly customer service.
To Hold or to Fold
The magnetic portable charger holds your iPhone 13/12 in place while charging and combines it with a kickstand that can unfold to function as a phone stand.
Two-Way Charge
Consisting of USB-C input and output ports, you can now quickly recharge the portable charger or power up any compatible USB-C devices.
Safety First
Anker's exclusive MultiProtect technology comes with advanced safety features like temperature control, overload protection, and more to let you charge with zero worries.
Compatibility:
iPhone 13 / iPhone 13 Pro / iPhone 13 Pro Max / iPhone 12 / iPhone 12 Pro / iPhone 12 Pro Max with a magnetic phone case.
- For best results, use a 12W power adapter (not included).
- Not compatible with non-magnetic phone cases, such as OtterBox defender cases.
- Magnetic and metal attachments such as cards, keys, and pop grips will interfere with charging.
- The magnetic charge provides up to 7.5W maximum power.
- When the portable charger is charging or discharging, some heat may be generated due to energy loss during transmission. This is a normal occurrence.
To hold or to fold
The magnetic portable charger holds your iPhone in place while charging and combines it with a kickstand that can unfold to function as a phone stand. -
Loaded with power
For its modest size that fits in the palm of your hand, the 5000mAh capacity magnetic portable charger is able to provide 17 hours of extended use. -
Two-way charge
Consisting of USB-C input and output ports, you can now quickly recharge the portable charger or power up any compatible USB-C devices. -
Safety first
- Anker 622 (MagGo) wireless charging stand / power bank - 24 pin USB-C - 7.5 Watt
- Product Type
- Wireless charging stand / power bank
- Designed For
- Mobile phone
- 6.55 cm x 10.5 cm x 1.28 cm
- 140 g
- Interstellar grey
- Output Connector Type
- 24 pin USB-C - on cable: USB-C
- Wireless Charging
- Battery
- 5000 mAh
- Power Provided
- 7.5 Watt
- Cables
- USB-C to USB-C cable - 60 cm
- 2-year warranty
- Designed For
- Apple iPhone 12, 12 mini, 12 Pro, 12 Pro Max, 13, 13 mini, 13 Pro, 13 Pro Max
- Product Type
- Designed For
- Mobile phone
- 6.55 cm
- 10.5 cm
- 1.28 cm
- 140 g
- Enclosure Colour
- Interstellar grey
- Input Connectors
- 24 pin USB-C
- Output connectors
- 24 pin USB-C
- Power Provided
- 7.5 Watt
- Detachable Cable Connector Type
- USB-C
- Wireless Charging
- MagSafe Compatibility
- Built-in foldable stand, built-in magnets, MultiProtect, 7.5W wireless output
- Capacity
- 5000 mAh
- Battery level indicator
- Cables Included
- Limited warranty - 2 years
- Designed For
