The Super Slim and Even More Powerful RoboVac with WiFi Connectivity
Lean, Mean, Cleaning Machine
RoboVac may be super slim, but it’s packed with a 3 point cleaning system, BoostIQ™ technology, and up to 1500P a of suction power to ensure your floors and carpets are clear of all dirt, dust, and crumbs. And with WiFi built in, you can accomplish all your cleaning needs from your smartphone.
Eliminate Vacuuming Chores
RoboVac takes on dust busting around your home so you don’t have to. Multiple cleaning modes and auto clean scheduling ensure an effortless, thorough clean while you relax.
Improved Cleaning
Refined from the inside and out to provide quiet vacuuming with zero hassle, RoboVac cleans with the equivalent sound of an operating microwave, and has been reduced to only 2.85" tall to clean under low hanging furniture with ease.
Cleans Further
A larger 0.6L dustbin allows RoboVac to pick up more dirt and dust to take full advantage of 100 minutes** of continuous cleaning, eliminating the need to empty it halfway through cleaning.
Premium Components
The anti scratch material cover provides a sleek look and superior protection for RoboVac, while the triple layer high performance filter achieves a better clean for your home.
Worry Free Warranty
At eufy, we believe in our products. That's why we back them all with a 12 month warranty and provide friendly, easy to reach support.
For Optimal Use:
- Use on low to medium pile carpets, tile, laminate, and hardwood floors. Not suitable for high pile carpet
- Move cables out of the way to avoid entanglement. 5 cable ties are provided in the package to help you better organize wires and power cords.
- Standard suction mode (hardwood floors) provides approx. 100 minutes of cleaning.
- BoostIQ™ mode (carpeting) provides approximately 60 minutes of cleaning
Lean, mean, cleaning machine
RoboVac may be super-slim, but it's packed with a 3-point cleaning system, BoostIQ technology, and up to 1500P a of suction power to ensure your floors and carpets are clear of all dirt, dust, and crumbs. And with Wi-Fi built-in, you can accomplish all your cleaning needs from your smartphone. -
Eliminate vacuuming chores
RoboVac takes on dust-busting around your home so you don't have to. Multiple cleaning modes and auto-clean scheduling ensure an effortless, thorough clean whileyou relax. -
Improved cleaning
Refined from the inside and out to provide quiet vacuuming with zero hassle, RoboVac cleans with the equivalent sound of an operating microwave, and has been reduced to only 2.85" tall to clean under low-hanging furniture with ease. -
Cleans further
A larger 0.6L dustbin allows RoboVac to pick up more dirt and dust to take full advantage of 100 minutes of continuous cleaning, eliminating the need to empty ithalfway through cleaning. -
Premium components
The anti-scratch material cover provides a sleek look and superior protection for RoboVac, while the triple-layer high-performance filter achieves a better clean for your home.
- Eufy RoboVac 35C - vacuum cleaner - robotic - black
- Product Type
- Vacuum cleaner
- Cleaner Type
- Robotic
- Compatible Floor Type
- General purpose
- Cleaning Method
- Dry
- Control Type
- Electronic
- Control Elements
- Touchpad
- Communications Technology
- Wi-Fi
- Intelligent Assistant
- Google Assistant, Alexa
- Dust Collection
- Bagless
- Operating Autonomy
- 100 min
- Sound Pressure Level (SPL)
- 55 dB
- Power Consumption
- 40 W
- Black
- 32.5 cm x 32.5 cm x 7.25 cm
- 2.37 kg
- 1 year
- Product Type
- Vacuum cleaner
- Cleaner Type
- Robotic
- Vacuum Cleaner Type
- General purpose
- Carpet, hard floor
- Cleaning Method
- Dry
- Dust Collection
- Bagless
- Filter Type
- High Performance filter
- Dust Capacity
- 0.6 litre
- Suction Pressure
- 1.5 kPa
- Room Navigation
- Black
Settings, Controls & Indicators
- Control Type
- Electronic
- Control Elements
- Touchpad
- Programmable Cleaning Intervals
- Cleaning Intervals Timer
- Weekly
- Smartphone Compatible
Internet of Things (IoT)
- Wi-Fi
- 55 dB
- Included Accessories
- Boundary marker
- Power Type
- Rechargeable batteries
- 100 min
- Battery
- Lithium Ion
- Battery Voltage
- 14.4 V
- Battery Capacity
- 2600 mAh
- Full Charge Time
- 6 hrs
- Power Consumption
- 40 W
- 32.5 cm
- 32.5 cm
- 7.25 cm
- 2.37 kg
- Warranty
- 1 year
