Amazon Echo Show 5 – White
Quicklinx: F74GWS00 Mfr#: B07KD79YVL
Colours:
  • Compact 5.5" smart display with Alexa, ready to help.
  • Voice or video call friends and family with compatible Echo devices or the Alexa app.
  • Manage calendar, make to-do lists, get weather and traffic updates and cook with step-by-step recipes.
  • Watch films, news and TV programmes. Listen to songs, radio stations and audiobooks.
  • Voice control compatible devices or manage them using the display.
  • Personalise by choosing a favourite clock face or photo. Create routines and alarms to start your day.
  • Control your privacy with the Mic/Camera Off button or the built-in camera cover.
See and do more with Alexa
Echo Show connects to Alexa to give you vivid visuals on a 5.5" screen with crisp full sound—all in a compact design that fits in any room, in any home. See on-screen lyrics with Amazon Music. Set alarms and timers. Catch up on news highlights and film trailers. Check weather and traffic before you head out.
Entertainment for every part of your day
Catch up on today’s news and sports highlights. Watch film trailers. Follow step-by-step recipes. See song lyrics (UK only) and album art with Amazon Music. The perfect size to bring all this and more to any room, at a glance. Connect with others
Connect with others
You can call almost anyone hands-free, including UK mobile and residential numbers (from UK only. Emergency calling not supported), other Echo devices, the Alexa app and Skype. You can also link Alexa with your UK EE mobile phone account to ask Alexa to make and answer your mobile calls. With the Drop In feature enabled for room-to-room calling, quickly connect with Echo devices in your home. Let your household know when dinner is ready, ask someone for help with a chore or remind the kids to go to sleep—without having to raise your voice.
More ways to control your privacy
Alexa and Echo devices are built with multiple layers of privacy protection. For example, on Echo Show 5, you can turn off the mics and camera with the press of a button, or slide the built-in cover to easily close the camera. You also have control over your voice recordings. You can view, hear or delete them at any time.
Make your home smarter
Manage compatible smart home devices on the simple interactive display, or use your voice. Control lights and switches, set thermostats and view security cameras. Raise and shine the smart way Use the ambient sunrise lighting feature to get your day started right. You can also choose from several fun clock face designs.
Alexa has skills
With tens of thousands of skills (and counting), Alexa is always getting smarter. Skills are like apps and help you do more like play True or False or learn something new with wikiHow. Just say, "Alexa, help me get started with skills".
  • Connect with your favourite people
    Make hands-free video calls. Instantly connect to other supported devices in your home, or make a voice announcement to every room with a supported Echo device.
  • Make your home smarter
    Manage compatible smart home devices on the simple interactive display or use your voice. Control lights and switches. Set thermostats. View security cameras.
  • Make other nightstands jealous
Amazon Echo Show 5 - smart display - LCD 5.5" - wireless
Smart display - LCD 5.5"
Speaker Type
Active
Peak Power
4 Watt
Frequency Response
100 - 20000 Hz
Amplifier
Integrated
Display
LCD - 5.5" - 960 x 480 - touch screen
Camera
1 Megapixel
Wi-Fi, Bluetooth
Intelligent Assistant
Alexa - direct
Speaker Details
Speaker - mono - 100 - 20000 Hz - 4 Ohm - active
Sandstone
14.8 cm x 7.3 cm x 8.6 cm
410 g
1-year warranty
Microphone
Enclosure Colour
Sandstone
Speaker System
Speaker Type
Active
Peak Power
4 Watt
Frequency Response
100 - 20000 Hz
Amplifier
Integrated
IEEE 802.11a/b/g/n/ac, Bluetooth 4.2 EDR
Bluetooth Profiles
Advanced Audio Distribution Profile (A2DP), Audio/Video Remote Control Profile (AVRCP)
Display
Camera
1 Megapixel
Internet of Things (IoT)
Hub
Integrated
Communications Type
Cloud
Communications Technology
Wi-Fi
Alexa
Voice Control
Direct
Speaker System Details
Speaker Details
Speaker - mono - 100 - 20000 Hz CFR - 4 Ohm - active
Driver Details
Speaker: full-range driver - 1.65"
Connector Type
Audio line-out (mini-phone 3.5mm)
AC power adaptor
Power Source
AC power adapter
14.8 cm
7.3 cm
8.6 cm
410 g
Limited warranty - 1 year
