Allied Telesis PCI-Express Single Port Adapter: 2x 1G SFP Slot
Quicklinx: BWJRWS00 Mfr#: AT-2911SFP-001
  • Windows 8 (32/64 bits)
Allied Telesis 2911 Series Network Interface Cards feature a PCI Express (PCIe x1) design, providing the maximum possible bandwidth and bus efficiency while providing the benefits of low power consumption.
  • High reliability
    The 2911 Series Gigabit interface comes with a comprehensive Microsoft Windows utility which performs detailed tests, diagnostics and analysis.
  • Advanced manageability
    The priority queuing offered by the 2911 Series can help users set up the network based on their own needs. The comprehensive diagnostics and configuration software suite provides system administrators and engineers with a profound tool to analyze the adapter card and check specific data.
Allied Telesis AT-2911SFP - network adapter - PCIe 2.0 - SFP (mini-GBIC) x 1 - TAA Compliant
Network adapter
Plug-in card - low profile
Interface (Bus) Type
PCI Express 2.0 x1
Bus Voltage
3.3 V
Ports
SFP (mini-GBIC) x 1
8.8 cm x 6.9 cm
68 g
GigE
Data Transfer Rate
1 Gbps
Network / Transport Protocol
TCP/IP
IEEE 802.2, IEEE 802.3z, IEEE 802.1Q, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.3ac, IEEE 802.3az
Linux 2.6, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2008 (32/64-bits), Microsoft Windows Server 2003 (32/64-bits), Windows 8 (32/64 bits), Microsoft Windows Server 2008 R2 (32/64-bits), Microsoft Windows Server 2012 (32/64-bits), Microsoft Windows Server 2012 R2, Microsoft Windows Server 2012 R2 x64 Edition
Microsoft Certification
Compatible with Windows 7
TAA Compliant
5-year warranty
Network adapter
PCI Express 2.0 x1
Bus Voltage
3.3 V
Ports
SFP (mini-GBIC) x 1
Wired
Gigabit Ethernet
Data Transfer Rate
1 Gbps
TCP/IP
Remote Management Protocol
SNMP
Status Indicators
Link/activity
Flow control, auto-negotiation, VLAN support, IPv6 support, Quality of Service (QoS), Jumbo Frames support, Receive Side Scaling (RSS), Energy Efficient Ethernet, Forward Error Correction (FEC), Smart Load Balancing (SLB), checksum offload support, Extended Message-Signaled Interrupts (MSI-X), iSCSI remote boot, PXE 2.1 support, Transmit Side Scaling (TSS), General Error Correction (GEC)
1 - SFP (mini-GBIC)
Full-height bracket
UL, TUV, VCCI, C-Tick, EN55024, EN55022 Class A, FCC, RoHS
TAA Compliant
8.8 cm
6.9 cm
68 g
Limited warranty - 5 years
5 - 90% (non-condensing)
